Thread: raising the rev limit
Results 41 to 60 of 66
  1. #41 Re: raising the rev limit
    Kemmerer, Wyoming
    would you mind looking at the maf worksheet to verify I did it right? the only part I am confused about is how to feather the afr so its smooth.
  2. #42 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    wow. this is a way nicer excel sheet then the one i used to use...ill have to play with it a bit. can you send me a copy of the virgin excel sheet and your log that you plugged into the sheet
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #43 Re: raising the rev limit
    Kemmerer, Wyoming
    you bet
  4. #44 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    you have an email.
  5. #45 Re: raising the rev limit
    Kemmerer, Wyoming
    so just save and upload the smoothed table
  6. #46 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    basically yeah
  7. #47 Re: raising the rev limit
    Kemmerer, Wyoming
    so I took another scan and forgot to log the o2. I worked up another spread sheet with the previous scans o2 readings, do you think that is fine, or go scan again with more attention to detail?
    and I forgot to reset my fuel trims
  8. #48 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    the data will be worthless without reseting the trims. the O2 i dont think is such a big deal. definitely dont mix data from different scans it wont match up and will **** everything up. you need to reset trims and drive around town for at least 45 minutes before you start logging data for more changes.
  9. #49 Re: raising the rev limit
    do a few re starts too during the relearn of the fuel trims.
  10. #50 Re: raising the rev limit
    Kemmerer, Wyoming
    oh Ok I will try it again.
  11. #51 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    good call, i forgot that part...been way to long since i have done it this way.
  12. #52 Re: raising the rev limit
    Kemmerer, Wyoming
    Did you see my last email Paul?
  13. #53 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    ive been out of town, ill take a look tonight.
  14. #54 Re: raising the rev limit
    Kemmerer, Wyoming
    I think I got the maf smoothed out, I'm going to work on the VE tomorrow and see if I can get some of my LTFT numbers closer to 0. I've been reading a tuning guide and found another tool called "Table Modifier" the scan data thingy, and think I have a pretty good understanding on how to bring in my LTFT's. it also has a timing adjustment where you click "SHAZAM" and it adds 1 degree of timing to every cell that doesn't have kr, and takes away 50% of timing in cells that have kr. I dont want to change my idle so do you think 2000 rpm is a good rpm to start from and go up from there?
  15. #55 Re: raising the rev limit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    do you understand the process for tuning the VE?
  16. #56 Re: raising the rev limit
    Kemmerer, Wyoming
    I think so, I'm going to read the guide again tomorrow to get the process fresh in my head but basically, disable the maf, and ease into the throttle while watching for kr and take a scan. I think it said to go 50% throttle and if there is no kr, take it to 75%, but no more. The application will make the adjustments. If I read it right it said I might have to make like 12 adjustments
  17. #57 Re: raising the rev limit
    Arizona
    Do not jus throw timing in because you have no kr. You need to concious of areas where theres light load to where you can add alot of timing and higher transitional high load boost areas.
  18. #58 Re: raising the rev limit
    Kemmerer, Wyoming
    Quote Originally Posted by 91parkave View Post
    I was going to start adding timing at like 3600 and go to 6000. I'm only at like 15 in most of those cells now. Going to go 1 degree at a time and scan, im hoping for 22 but 20 will be good too
  19. #59 Re: raising the rev limit
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Looks like you're past the subject of adjusting the rev limiter, but I'd like to share my 2 cents... if you raise the rev limiter, you won't get the benefits without raising the shift points also (like bill said). I'd like to add that you should have at least a few hundred RPM between your shift point and rev limiter. Otherwise you can possibly bounce off the rev limiter mid-shift.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  20. #60 Re: raising the rev limit
    Kemmerer, Wyoming
    which table does raise the rev limiter?
  1. BLACKxFLAGx Raising It UP! plus suspension woes....
    By blackflag in forum Members Rides
    Last Post: 10-11-2013, 11:00 AM
  2. 4k limit at 90??
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2012, 05:56 AM
  3. raising offset on my wheels....yes or no?
    By twol8uluz in forum Tires & Wheels
    Last Post: 03-30-2012, 07:02 PM
  4. I swear I was doing the speed limit, wait what was it again?
    By jwjones in forum Off Topic Discussion
    Last Post: 01-04-2012, 09:02 AM
  5. PCM limit?
    By mzendano in forum Track Sessions and Kills
    Last Post: 11-30-2008, 03:40 PM
