Thread: The defacto guide to tuning your car for e85.
Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 225
  1. #141 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    More fuel isn't going to help you, going richer is the opposite of what I would want to do with E85.
    E85 is great at taking away heat, you should be able to lean the mixture out a little bit using E85.
    I was just about to go and ask my question again, but you answered it. should I change anything other than the maf if I'm only going to run the 40%-50% ethanol blend?
  2. #142 Re: The defacto guide to tuning your car for e85.
    Arizona
    honestly don't know why you change your maf curve for e85 or any blend. your stoic is what's ****ed up and needs changing. but since 3800 members don't like stoic adjustments. ifr would be your quickest solution
  3. #143 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    has anyone tried emailing HP Tuners to get them to finish mapping the afr table so the "stoic method" can be used effectively?
    and if I did just change the stoic, would I just change that one table? and if so, what would I put in?
  4. #144 Re: The defacto guide to tuning your car for e85.
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I emailed them to see about unlocking some other tables for it (fuel stuff). It's been two weeks and all I've got is a generic reply. So yeah.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #145 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    Quote Originally Posted by SgtMarshal View Post
    It won't work. You can literally put anything you want into that table, and the car will always correct it to 14.7 once the trims take over. Due to our o2 sensor, there is nothing you can do about it unless you run in open loop.
  6. #146 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    I read on this site that stochiometric for E70 is 10.69, so if I was running E70 that should be my target afr, correct?
    I am adding a methanol kit, and AEM says to lean the mixture by 1 point, so in this case my target afr would be 11.7, correct?
    any suggestions on where I should set the start psi for the methanol to start flowing and where I should set the full psi?
    http://www.ecmtuning.com/wiki/e85fuel
    http://aemelectronics.com/files/inst...ns/30-3300.pdf
  7. #147 Re: The defacto guide to tuning your car for e85.
    Read post above yours, it does not matter what you change stoich too, it will always correct it to 14.7.
    If you tune in lambda you need not worry about stoich, because stoich is stoich is stoich no matter the fuel you run. If you stay on the AFR scale just aim for similar numbers as you do now.
  8. #148 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    When in pe mode, isn't it in open loop? And wouldn't it target the afr that's commanded for pe?
  9. #149 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    Not really....commanded is usually nowhere near actual, unless you spend the time tuning to get it there.
    Keep your wideband calibrated for gas, and nothing changes. Shoot for 11.5 at wot. Then lean it out til you see knock. Or pulley down.
  10. #150 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    has anyone actually dyno tested different air fuel ratios of E85 to see what the different power levels are for the different ratios? I've been reading online and have found that E85 max power rich afr is like 6.429 and E85 max power lean is 7.8 while E85 stoich is 9.0078, so are we running our car's lean?
    it would take a lot of fuel to hit those ratios, and the car would probably run really rich all the time.
  11. #151 Re: The defacto guide to tuning your car for e85.
    Why would it take anymore fuel?
    I don't think you understand what is going on here. Just because the stoich ratio changes for the given fuel, doesn't mean it going to take a far richer commanded fuel number to achive your goals.
    This is why tuning in lambda makes all this nonsense simple when using E85. Stoich is stoich no matter the fuel you are running. You'd be tuning it for somewhere between .75 and .85 lambda.
    Because you are still using the gas scale on the wideband you have to think about it that way still. 6.429 commanded on E85 is like commanding 10.3 to 10.4 or so on the gas scale. That is still pretty rich. Going to the max lean on the E85 at 7.8 is like running upper 12's on the gas scale.
  12. #152 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    ^^That.
    Quit looking at posts where they are calibrating the sensor for e85. There are no benefits, and it will do nothing but confuse you.
  13. #153 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    this is what i've learned so far, correct me if I'm wrong: the wideband shows the same afr regardless of fuel used, so since the fuel used has been ethanol based the air fuel ratio will read richer than actual gasoline. The stochiometric ratio for E70 is 10.7, so that is what the air fuel ratio should be.
    I do plan on giving it all a rest because it really is confusing, but if what I posted above is true, then I think i have a handle on it.
  14. #154 Re: The defacto guide to tuning your car for e85.
    If the wideband is setup to use the gas scale and you run E85, it's still going to show the stoich is around 14.7 and not 10.7.
  15. #155 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    what would you guys put for the cylinder gain if the ethanol was 90% content? I was thinking 1.31
  16. #156 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    I've always done 30% increase and let trims do the rest.
  17. #157 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    http://www.grandprixforums.net/threa...t=97autoxvette
    using this method and targeting 9.8 in open loop, how close will that afr be to actual, and is it like the cylinder gain method where gas mileage is about 30% worse?
    or is it a vehicle specific thing and everyone's car is different?
  18. #158 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    It'll depend on the car, but should be somewhat close.
    But you are going out of your way to make this harder than it needs to be.
  19. #159 Re: The defacto guide to tuning your car for e85.
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Why not just change the ifr table and then ve and maf tune?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  20. #160 Re: The defacto guide to tuning your car for e85.
    Kemmerer, Wyoming
    that's too much work. ifr table should be a set and forget deal. it's much easier to change the cylinder gain. I just want to try something different.
  1. HKS: Beginners guide to tuning
    By matt5112 in forum General Tech Discussion
    Last Post: 09-22-2012, 10:09 AM
  2. Gary's tuning guide?
    By Sandman in forum PCM Tuning
    Last Post: 03-23-2011, 06:53 PM
  3. gtp buying guide
    By windycitygtp in forum General Tech Discussion
    Last Post: 01-18-2009, 09:09 PM
  4. The Compleate Fuel Economy Tuning Guide
    By TDCRacing in forum PCM Tuning
    Last Post: 07-09-2008, 11:43 AM
