Thread: The defacto guide to tuning your car for e85.
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 181 to 200 of 225
  1. #181 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    04lss
    I am using new Deka 60 injectors. I’d have to look up somewhere what my stock injectors are.
  2. #182 Re: The defacto guide to tuning your car for e85.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    someone else with more experience may correct me, but i think the ratio method is a good place to start. Should get you close enough to run the car at any rate.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #183 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I think my stock injectors are 32# if I’m not mistaken. I’m not exactly sure though how to get the correct number from the Deka 60s???????????????!!!
  4. #184 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m hoping to get my car going as a DD soon! If anyone has instrutuctions/how to for this as a complete process, please point it out!!!!!
  5. #185 Re: The defacto guide to tuning your car for e85.
    Sep 2014
    Richmond Virginia
    60/32 is 1.875. Multiply the flow rate in injector flow rate table by 1.8.
    If you are also doing e85, the injector offset should be multiplied by about 1.3 . That should be enough to get your car running.
  6. #186 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    Every fuel type has its own stoichiometric value. But all your wideband cares about is lambda, which displays as 14.7 on your gauge. Lambda is the same for all fuels, optimally being 1. But your pcm is calculating everything based on 14.7. if you change this you will also affect other tables that either need to be changed or probably some that we don't have access to. So best to just leave it as is and tune as you would.
    Top Swapped 01 Imp
  7. #187 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok my Injectors flow rate table is as follows 84.4-101.1.
    I put cylinder gain @ 1.2251
    That’s what I have so far. Anything else to set??
  8. #188 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m not sure what’s to be multiplied by 1.3 04lss? Anyone’s help would set me up nicely. I’m just watching and refreshing this screen frequently!!!!!
  9. #189 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I can’t get it running at any settings. Frustrating is what it is all becoming. I thought the settings were all good but it turns out that they are wrong. I’m going to have to find someone who is not afraid to help with the whole situation. Someone please help from the beginning to the end.
  10. #190 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    What injectors are you running?
  11. #191 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m running the Deca 60s.
  12. #192 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I multiplied my fuel injector table by 1.8. I put the injector gain÷ injector screw to 1.2251. It will not stay running like this! Anyone have any suggestions? I’d like to get this driving. ASAP!
  13. #193 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    Your injector table should be about correct, assuming your car was supercharged from the factory. If it wasn't, we need a different calculation. Also, make sure your injector table was 100% stock before you did the calculation.
    Your injector skew should also be set at 1.34.
  14. #194 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    What is your injector settings? Trying to compare. This thing does not want to run!
  15. #195 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    This starts right up but will not idle at all. I’m not sure what is going on here. Something is not right with the numbers I multiplied the stock against.
  16. #196 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    I haven't looked at mine for awhile but I was closer to 58 I think. Yours sounds way off for 60's
    Top Swapped 01 Imp
  17. #197 Re: The defacto guide to tuning your car for e85.
    Apr 2015
    Columbus, OH
    Upload and link your tune here. Someone will check it out. I can later
    Top Swapped 01 Imp
  18. #198 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It wont allow me to send the file because it is too big. I will have to send it someones private email. or if anyone knows how to attach it to the message here. It keeps telling the file is too big. rickisrad04@yahoo.com
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  19. #199 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It will not let me download the tune here. It is too big. send me your e-mail and I will send it your way.
  20. #200 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Now I am at 1.3401 cylinder gain. Injectors fuel flow is from “53.3up to 63.9” manifold vacuum. still won’t keep it running
  1. HKS: Beginners guide to tuning
    By matt5112 in forum General Tech Discussion
    Last Post: 09-22-2012, 10:09 AM
  2. Gary's tuning guide?
    By Sandman in forum PCM Tuning
    Last Post: 03-23-2011, 06:53 PM
  3. gtp buying guide
    By windycitygtp in forum General Tech Discussion
    Last Post: 01-18-2009, 09:09 PM
  4. The Compleate Fuel Economy Tuning Guide
    By TDCRacing in forum PCM Tuning
    Last Post: 07-09-2008, 11:43 AM
