Thread: HPT trouble with histogram of Wideband
Results 1 to 9 of 9
  1. #1 HPT trouble with histogram of Wideband
    Sep 2014
    United States
    I am using my EGR to log my Wideband o2 data in HPT. It shows up in the charts so i know it is logging. But i can not get it to come up correctly in the histogram. My current setup is as follow.
    Plot Value:
    Sensor: blank
    PID: WBegr
    units: afr
    Decimals: 2
    Row & Col Axis
    MAF Airflow vs Output Frequency
    Secondary
    Col(Top) Axis Header
    Sensor: Mass Air Flow Frequency
    Row(Left) Axis Header
    PID: WBegr
    Im pretty sure its in my Row & Col Axis that is wrong. Any help would be great.
    02 Grand Prix GT Mods' Top Swapped Gen 3, Stage 2 IC, 3.0" MPS, 42# injectors, 1.8 Yella Terra roller rockers, Speed Daddy Headers, CAI, Self Tuned, 180 tstat, ram air hood, front/rear sway bars/and STB's AL 104's, 12' Dual Piston Break kit
  2. #2 Re: HPT trouble with histogram of Wieband
    gardner,mass
    You need to have egr voltage and egr pid logged or the pid wont work
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: HPT trouble with histogram of Wieband
    Sep 2014
    United States
    Do you mean after i add the EGR position, WBEGR and EGR AFR Error from the steps i followed here?
    rhttp://www.grandprixforums.net/threa...-EGR-connector
    Then i need to drive the car around to get a log, if so then i have done that. I am new to this so bear with me!
  4. #4 Re: HPT trouble with histogram of Wieband
    He's saying that in order for your wideband PID to work, you must log the EGR volts in the table display.
    Because the PID you made is getting power from somewhere and the VCM scanner needs to see that voltage. So your EGR is the power source and all you PID info comes from the EGR, so it must be logged in the table display to produce data.
  5. #5 Re: HPT trouble with histogram of Wieband
    Sep 2014
    United States
    This is what i have in my table right now.
    http://i294.photobucket.com/albums/mm98/beatdowncity/egr-1.png
  6. #6 Re: HPT trouble with histogram of Wieband
    gardner,mass
    Yea thats right. So whats the issue? You just set your histogram to the same settings as that pid iirc.
    Give me 1 minute ill grab you my settings.
  7. #7 Re: HPT trouble with histogram of Wieband
    gardner,mass
    I have ny histogram set as follows
    Name: Maf wot tuning
    Pid: wideband ( this is my user defined pid name)
    Units: :1
    Decimals:2
    Value high 20
    Value mid 0
    Value low 10
  8. #8 Re: HPT trouble with histogram of Wieband
    Sep 2014
    United States
    Mine is the same except under units i have afr, what do you have under row & Col Axis?
  9. #9 Re: HPT trouble with histogram of Wideband
    Sep 2014
    United States
    I figured it out now, thx for help!
  1. Wideband, Histogram & HPTuners
    By rperry435 in forum PCM Tuning
    Last Post: 05-10-2013, 12:00 AM
  2. New to GP from bmw and already having trouble !!! help !!
    By 01gtp1506 in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 08:23 AM
  3. car trouble Help please
    By grandprixxx94 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-29-2011, 07:13 AM
  4. KR on the Chart display but not on histogram
    By Explicit_Spade in forum PCM Tuning
    Last Post: 09-16-2011, 07:02 PM
  5. AC Trouble
    By NickF87 in forum General Tech Discussion
    Last Post: 03-01-2010, 10:14 PM
