So I'm sending my pcm to zzp for tuneing. i have a pcm out of a 2000 gp gt. mine is a 98 gp se. Will i be able to use the one out of the 2000 till i get mine back or should i go find another to put in
Being an SE, are you a 3.1L? If so.. then the GT pcm will not work well in your car.
In that case, I'd send them the GT pcm and your vin to load the new tune with your vin onto.
Mine is a 3.8. won't go near a 3.1 lol
I'd want to confirm the gear ratios are the same, IIRC all NA GP's are 3.29, but I'm not 100% sure on that. Otherwise the BCM and a few other little things might be pissed with the newer pcm.
