I'm positive.
You're right on one point, 97-2000 did use that type of PE vs RPM table, but in the 2001 and later cars (in this case) they leaned out the table. Take a look at a stock file and you will see. At 0 seconds 4200, it's only subtracted roughly .5 from the AFR, it only maxes out at the redline at -1.3 and subsequently drops to between .5 and .75 at the shift where it stays pretty level until 7-8 seconds in. It never really drops the AFR to a consistent 1.0 until after 8 seconds until it begins to add fuel until either A. the end of the run or B at 25 seconds which it drops the AFR to the 9's.
You have to pay close attention to what years you're referring to, because not every PCM is programmed the same, especially when you get into the 2003 and later models.
