Thread: Heavy kr after warm up?
Results 1 to 10 of 10
  1. #1 Heavy kr after warm up?
    gardner,mass
    Randomly some days after i let the car warm up my first initial say 5-10 minutes of the drive i get heavy kr ( up to 8*) under light throttle. Ive seen some posts on this befor but no answers. Sure i could take some timing out there but just wondering if im missing something else.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Heavy kr after warm up?
    Howell, NJ
    Then it goes away after the 5-10 minutes?
  3. #3 Re: Heavy kr after warm up?
    GTP Level Member buickman104's Avatar
    NYC
    Coils or ICM might be bad.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Heavy kr after warm up?
    gardner,mass
    Didnt think of that but i have another set of coils. Ide guess icm if either of those though. Im scan it one morning and see what my exact temps look like during that period and when exactly it goes away.
  5. #5 Re: Heavy kr after warm up?
    i should try a new icm and coils, maybe its the cause of my own kr. i dont have misfires or anything being reported for a mis tho.
  6. #6 Re: Heavy kr after warm up?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by Ginseng View Post
    The problem might have nothing to do with being warmed up, you might be getting knock all the time. The knock sensors don't cause pulled timing (retard) until 162* if I'm not mistaken.
    As for the knock itself... maybe the front O2 sensor is going bad (Leaning out cruise AFR and causing knock)?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Heavy kr after warm up?
    gardner,mass
    front o2 is new, and i thought of this already and am wondering if maby im not seeing knock untill exactly 162 and then once it warms up fully the air density changes and the knock goes away therefor im only seing knoc between say 162-180
  8. #8 Re: Heavy kr after warm up?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Was it replaced with an AC Delco or random parts store brand o2? I just changed from a parts store brand to an AC delco sensor and my car is reading very different fuel trims and gas milage bumped up quite a bit and a couple o2 codes went away... Anything other than an AC delco sensor is junk from what I've seen.
    04 GTP -HAI, 1.9 rockers.
  9. #9 Re: Heavy kr after warm up?
    When your file\tune was originally setup, your knock sensor temp should have been set much lower. Take a moment and set it lower if it isn't.
    Danomite may have a pile of coils etc.
  10. #10 Re: Heavy kr after warm up?
    gardner,mass
    Yea ima install the cam wend morning and retune the car. I already planned on setting it lower when i was looking threw my bin the other day.
    I have a denso o2 and have used them with many vehicles without issues.
  1. ILoveAudi's 98 GTP - Turbo Hoopty
    By ILoveAudi in forum Members Rides
    Last Post: 03-19-2016, 03:16 PM
  2. 02 GT heater blows warm air, then cold, then warm, etc.
    By skeelo58 in forum General Tech Discussion
    Last Post: 03-04-2014, 08:52 PM
  3. getting warm
    By Lil larry in forum General Grand Prix Discussion
    Last Post: 07-07-2013, 11:12 AM
  4. Warm greetings
    By ailixhomes in forum Introductions/Noob Questions
    Last Post: 08-17-2012, 05:55 PM
  5. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
