Thread: Tuning for optimal mpg with DHP
Page 4 of 4 FirstFirst ... 234
Results 61 to 69 of 69
  1. #61 Re: Tuning for optimal mpg with DHP
    i used the values posted by zafrin and gained about 1.8 mpg on my local. highway i still get high 20's to 30 easy.
  2. #62 Re: Tuning for optimal mpg with DHP
    Kemmerer, Wyoming
    on a side note, the values zalfrin suggested have to be entered in using tiny tuner. dhp does not have adjustment capabilities for those tables.
  3. #63 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Quote Originally Posted by SgtMarshal View Post
    I thought I saw a dhp guide on tuning for optimum fuel economy, but after looking through Bill's drop box, I have come up empty handed. maybe I need to do some more searches.
    There was a small section on that in Jerry's Tuning Notebook.
  4. #64 Re: Tuning for optimal mpg with DHP
    Kemmerer, Wyoming
    Quote Originally Posted by Zalfrin View Post
    I saw that after a while, it was at the very end.
  5. #65 Re: Tuning for optimal mpg with DHP
    Donating Users moddman's Avatar
    Midwest
    Take a peek at the PE Enable Cylinder Mass Air vs RPM table in thingy suite or tiny tuner. GM left this zeroed out for all 97-03 w-bodies, so as a result most tuners will use TP% to decide when to enter PE. This either results in worse fuel economy from entering PE too early, or knock from entering PE too late. Using cylinder air mass is a better solution since it relates to engine load. I used PE Enable TPS of 15-30% coupled with the cylinder air mass enable (both conditions must be met for PE to be triggered, so you want to set the TP% low). Result was a vastly improved daily driving experience. Give it a try some time. Table I used for cylinder mass enable follows.
    520
    520
    520
    420
    480
    480
    440
    460
    460
    400
    85
    This should be a good start, basically what you're doing is using engine load to determine when to enter PE. You can raise the cylinder mass numbers to enter PE at a higher load, or lower to enter at lower load. If you want to tune the numbers further, you want to enter PE as late as possible while still maintaining no knock in order to maximize fuel economy.
    Where do you start from for adding this data? Zero(0) is the first value on the left in Tiny Tuner, then it is 400. The reason why I ask is you have 16 values and Tiny Tuner has 17 values starting from 0 to 6400. Just thought this would help clarify things for all of us.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  6. #66 Re: Tuning for optimal mpg with DHP
    pm me your email, ill send you my bin and you can copy it if you want.
  7. #67 Re: Tuning for optimal mpg with DHP
    Kemmerer, Wyoming
    just put in an extra 520
  8. #68 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Quote Originally Posted by moddman View Post
    Whoops! I left out one "460", here's another try if you're curious.
    520
    520
    520
    420
    480
    480
    440
    460
    460
    460
    400
    85
  9. #69 Re: Tuning for optimal mpg with DHP
    Kemmerer, Wyoming
    thanks for the clarification
  1. VE Tuning... wtf?
    By JerzNick in forum PCM Tuning
    Last Post: 08-21-2013, 02:09 PM
  2. Optimal Boost vs AFR vs Timing
    By Max Cook in forum General Tech Discussion
    Last Post: 10-27-2012, 06:23 PM
  3. Need some help on MAF tuning
    By Sandman in forum PCM Tuning
    Last Post: 01-09-2012, 06:55 PM
  4. pcm tuning!
    By gunsn88 in forum PCM Tuning
    Last Post: 10-15-2011, 02:58 PM
