Thread: Tuning for optimal mpg with DHP
Results 41 to 60 of 69
  1. #1 Re: Tuning for optimal mpg with DHP
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    Btw I played with the AE and PE values on my last bin and it helped a lot wouldn't kick into boost as soon and when it did it doesn't feel like it's just jumping in BUT I needed to mess with one I think AE because I was using just as much gas even though I wasn't in boost so the AE was set to high I can send you my bin so you can check it out if you want
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  2. #2 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Take a peek at the PE Enable Cylinder Mass Air vs RPM table in thingy suite or tiny tuner. GM left this zeroed out for all 97-03 w-bodies, so as a result most tuners will use TP% to decide when to enter PE. This either results in worse fuel economy from entering PE too early, or knock from entering PE too late. Using cylinder air mass is a better solution since it relates to engine load. I used PE Enable TPS of 15-30% coupled with the cylinder air mass enable (both conditions must be met for PE to be triggered, so you want to set the TP% low). Result was a vastly improved daily driving experience. Give it a try some time. Table I used for cylinder mass enable follows.
    520
    520
    520
    420
    480
    480
    440
    460
    460
    400
    85
    This should be a good start, basically what you're doing is using engine load to determine when to enter PE. You can raise the cylinder mass numbers to enter PE at a higher load, or lower to enter at lower load. If you want to tune the numbers further, you want to enter PE as late as possible while still maintaining no knock in order to maximize fuel economy.
  3. #3 Re: Tuning for optimal mpg with DHP
    Mar 2013
    Staten Island, NY
    I don't have DHP anymore I have HP tuners now but I'm at the PE tps vs rpm if that's what you mean? And my numbers are 40, 40 etc etc etc not 3 digits unless yours is 58.0
  4. #4 Re: Tuning for optimal mpg with DHP
    Donating Users moddman's Avatar
    Midwest
    Quote Originally Posted by Zalfrin View Post
    520
    520
    520
    420
    480
    480
    440
    460
    460
    400
    85
    Where do you start from for adding this data? Zero(0) is the first value on the left in Tiny Tuner, then it is 400. The reason why I ask is you have 16 values and Tiny Tuner has 17 values starting from 0 to 6400. Just thought this would help clarify things for all of us.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  5. #5 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Quote Originally Posted by moddman View Post
    Whoops! I left out one "460", here's another try if you're curious.
    520
    520
    520
    420
    480
    480
    440
    460
    460
    460
    400
    85
  6. #6 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    that's PE enable by throttle position. There's another table that allows you to enable to cylinder air mass (basically engine load) instead, but I don't think HPT gives you access to it.
  7. #7 Re: Tuning for optimal mpg with DHP
    Mar 2013
    Staten Island, NY
    Yea can you use tiny tuner? If you know
  8. #8 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    With HPT? Sort of... I believe you can read in a .bin once, then it gets converted to a .hpt. So you could start with a stock .bin for your vehicle, modify it with TinyTuner, than load it with HPT. But you can't (easily) go the other direction (from hpt to bin)
    AFAIK anyways, I've never had HPT so I'm just going on what I've read.
  9. #9 Re: Tuning for optimal mpg with DHP
    i cant get tiny tuner to save these changes. keeps saying error cant find table 0.
    any idea what im doing wrong? wont save in any chart.
  10. #10 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Not sure, did you follow the instructions in the Read Me First file to get the database pulled in?
  11. #11 Re: Tuning for optimal mpg with DHP
    ill have to re check the install i guess, it said run i hit run and it loaded my bin. just wont make changes.
  12. #12 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Eddie is the expert since he wrote this stuff. Perhaps you're using an OSID that's not in the database? But if that were the case you shouldn't see any tables listed. Could be the access database is malformed, I don't know that the public release has ever went through much testing. Try loading a different OSID bin out of curiosity to see if it's specific to yours.
  13. #13 Re: Tuning for optimal mpg with DHP
    i didnt have the data base d'l'ed. trying again now.
  14. #14 Re: Tuning for optimal mpg with DHP
    it still refused to take my bin, tried another one, it took, so i then went to my bin and it saved it, put your numbers in and then took 10% out of the tps on each line to 2800. that sound ok you you?
  15. #15 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    Sounds reasonable, flash it and do a scan while trying it out. If you load the scan into table modifier, you can see what the calculated cylinder air mass was if you need to do any tweaking of the PE start points.
  16. #16 Re: Tuning for optimal mpg with DHP
    more stuff to download i see lol ill toss it in tomorrow, see how it goes.
  17. #17 Re: Tuning for optimal mpg with DHP
    Jul 2010
    Iowa
    One more table to take a look at: PE A/F vs TPS. I ended up richening this up quite a bit over stock since you're hitting PE at lower throttle now. Table I used below.
    0.4501953
    0.2597656
    0.09960938
    0.009765625
  18. #18 Re: Tuning for optimal mpg with DHP
    you would post this after i logged of my other os with all the tuner stuff on it lol
    if my laptop was not in my car and 2000 feet away
  19. #19 Re: Tuning for optimal mpg with DHP
    Feb 2009
    flintnasty MI
    99% chance you are not using the "use database when available" function, or you are trying to use an unsupported OSID, which in that case you need to add it to the database.
  20. #20 Re: Tuning for optimal mpg with DHP
    closer to 100% chance. i had to d/l the database then tried both settings. when available did it.
  1. VE Tuning... wtf?
    By JerzNick in forum PCM Tuning
    Last Post: 08-21-2013, 02:09 PM
  2. Optimal Boost vs AFR vs Timing
    By Max Cook in forum General Tech Discussion
    Last Post: 10-27-2012, 06:23 PM
  3. Need some help on MAF tuning
    By Sandman in forum PCM Tuning
    Last Post: 01-09-2012, 06:55 PM
  4. pcm tuning!
    By gunsn88 in forum PCM Tuning
    Last Post: 10-15-2011, 02:58 PM
