you cant change "fuel settings" because you will constantly be in closed loop, which corrects for any fuel changes you make.
Best things you can do is disable cat warm up timing cut, and disable alot of the warmup enrichment settings. After that add a ton of timing.
Then you can try going open loop and running lean cruise.
