Thread: Can't get my DHP registered
Page 5 of 5 FirstFirst ... 345
Results 81 to 99 of 99
  1. #81 Re: Can't get my DHP registered
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    I'm gonna buy a new usb to serial adapter in the am and try that and see if I'm gonna meet up with my friend.. If I get this cable install the driver etc I'd assume it's the DHP but like I said I had it working before the driver got messed up so I have faith that it's the cable! If not I will have my friend hook my DHP in place of his and see if it works
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  2. #82 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
  3. #83 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    OK so! I bought the USB to serial adapter this morning http://www.staples.com/Staples-USB-t...product_837560 this one to be exact. No where around here sells the Keyspan anyway so I hooked it up installed the driver. Connected the DHP to the car/PC and did the interface registration and guess what! It failed the same exact way! So before I snap out I messed with the speed settings on the COM 3,4,5 and 7 in said order. Once I got to 7 I did the registration and was looking at something besides the computer cause I figured it would fail anyway. I turn back around to retry it and it says "Registration Complete" for a moment I was like wtf? What just happened? So I go to read my PCM and it doesn't work over and over I try (97 GTP not 01 GT) so I was like let me start the car it's like 100 degrees I'm sweating and I will try to scan live data see if that works. So I scan and it works fine so I'm like hmm why won't it read my PCM it's a ZZP PCM but was edited with DHP by a friend a few months ago so it should read! But either way I tried like 4 times and the switched it to "force upper case VIN" and bam it worked! Now I'm not sure as to why that helped BUT it did so now everything so far KNOCK ON WOOD!!! Is working good so if you're having the same "Interface Registration" issue I suggest a few things.
    1. Check speed settings (COM on the computer end, DHP software).
    2. If you have a cheap USB to serial adapter get either Keyspan or the one I posted above.
    3. Try ALL your USB ports with all speed settings.
    4. Check, reinstall drivers for your adapter if you don't have the actual adapter drivers download several and keep trying.
    This was on my HP laptop with Windows 8.1, 64 bit, Powrtuner Software v1.2.4, 115,200 speed.
  4. #84 Re: Can't get my DHP registered
    congrats!!!! persistence pays off.
    i know what a pita it can be get it done. but like i said earlier, when it does register that progress bar means jack, it happens fast.
  5. #85 Re: Can't get my DHP registered
    GT Level Member jdmgtp's Avatar
    MI
    yes and thanks to everyone who helped.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  6. #86 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    You got it jdmgtp? I don't think your unit is trash just it's very picky
  7. #87 Re: Can't get my DHP registered
    Quote Originally Posted by jdmgtp View Post
    so Darkhorizon was able to figure it out for ya? if so good deal.
  8. #88 Re: Can't get my DHP registered
    MI
    Well WE figured it out using his unit. it's not picky it was just a bad cable
  9. #89 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    So we both had a bad cables smh well at least it didn't take 2 weeks lolol
  10. #90 Re: Can't get my DHP registered
    yup, less than 2 weeks to get it right don't sound to bad.....you guys had it easy lol
  11. #91 Re: Can't get my DHP registered
    MI
    Yea it was the obd cable. I made a post but apparently it didn't go through
  12. #92 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    Oh yea? I found a place that sells them cheap if you want it
  13. #93 Re: Can't get my DHP registered
    Feb 2009
    flintnasty MI
    I just gave him avt parts and said random things. I did notice he had a goofy 9ft cable that was labeled DHP and not avt like all of the ones I have had.
  14. #94 Re: Can't get my DHP registered
    MI
    Lol
  15. #95 Re: Can't get my DHP registered
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    My unit which has a higher firmware and serial # than the ones all of you guys posted (2.9/3800xx) also has the 9ft. obd cable thats labeled DHP.
    I'll have to keep that in mind if I ever have any issues...fortunately my registered like a charm first time, it however had been a one owner unit that had been meticulously cared for and still looks brand new.(Thanks Foghorn!)
    Glad to see you both got yours up and running!
  16. #96 Re: Can't get my DHP registered
    Feb 2009
    flintnasty MI
    step one of DHP is make sure that the red light flashes on the box... If thats not happening dont even bother hooking up a serial cable.
  17. #97 Re: Can't get my DHP registered
    the one i have must be old as sh-it, cause theres no red light on the box.
  18. #98 Re: Can't get my DHP registered
    Mar 2013
    Staten Island, NY
    I didn't realize it either till I was checking the wires etc but I don't know if they all have it
  19. #99 Re: Can't get my DHP registered
    Quote Originally Posted by 231FUN View Post
    If you hang out with Paul at times, tell him I said hi. On a side note....I've touched that cable, so there's at least a couple of fingerprints on it.
  1. Just Registered ! From INdiana
    By Logan in forum Introductions/Noob Questions
    Last Post: 09-10-2010, 11:45 AM
  2. Finally registered.. red gtp
    By Perry125 in forum Introductions/Noob Questions
    Last Post: 08-22-2009, 09:58 AM
  3. finally registered....
    By kfog in forum Introductions/Noob Questions
    Last Post: 06-20-2009, 10:44 AM
