Thread: 05 GP Base P0053 and P0520 codes
Results 1 to 4 of 4
  1. #1 05 GP Base P0053 and P0520 codes
    SE Level Member Yonkerse's Avatar
    Aug 2011
    Southwest Michigan
    Hey guys,
    I have posted a few times before on my g/f car which I have been working on and fixing little issues with. Most recent one was the starting issue she was having when the car wouldn't always catch. Cleaning the throttle body and MAF sesnor took care of this!!!
    Recently, I had given the car a tune up with new plugs, wires, and front O2 sensor. The O2 sensor didn't have the identical female mating piece as the original, so I modified it to make it work. She drove the car around for a bit, and her check engine light came on. Plugged in my Aeroforce and got the P0053 code which is for the front O2 sensor..so im currently in battle with Napa to get the correct O2 sensor for this..
    The second code (P0520) is the "Oil Sender Sensor" which appears to be located by the oil filter on passenger side. Does anyone have a picture of this or a possible write up? I did a search and didn't see anything, not to say its there with different key words. The part is only $12 at Autozone, so wanted to get this squared away for her as well.
    Sorry for such a long post for simple question! haha,
    Thanks for the help!
  2. #2 Re: 05 GP Base P0053 and P0520 codes
    Please pull a pic of the sender from my pb account
    psd: Boosted
    Under Helpful Pictures there's a couple subcategories about engine or back of engine to trans. Look in there and you'll see the sensor you are looking for on the oil filter adapter.
    It's most accessible through the passenger wheel well.
  3. #3 Re: 05 GP Base P0053 and P0520 codes
    Aug 2011
    Southwest Michigan
    Hey Bill,
    Thanks for supplying the information to the location of the sensor. Really helps seeing actual pictures of where the part is located. Does that just plug into its location once the wire connection is removed?
    Thanks again!
    Eric
  4. #4 Re: 05 GP Base P0053 and P0520 codes
    It's threaded in.
  1. 05 grand prix base
    By kmk2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 04:53 PM
  2. 2007 Base vs 1999 GTP
    By Brien in forum Off Topic Discussion
    Last Post: 12-24-2010, 01:02 PM
  3. Supercharger for Base 05 GP
    By kyledc2000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2010, 09:55 PM
  4. ZZP's customer base
    By matt5112 in forum Off Topic Discussion
    Last Post: 11-19-2009, 10:39 PM
  5. Base model in need of a Supercharger
    By imjustanobody34 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 12:07 PM
