Thread: stage 2 t.b. tuning help
Results 1 to 20 of 22
  1. #1 stage 2 t.b. tuning help
    Sep 2013
    Massachusetts north shore
    Hi guys i installed a used stage 2 throttle body and my tune is so bad from the start my ltft +16 and after a maf tune i am getting them close to + 5 i also changed the tp pe table lower and more pe at 20-30 % throttle i am getting lots of kr, with less than 2 psi of boost i am getting 2-5° kr and i think 4 psi i can hear the detonation over 10° of kr i immediately let off where should i start and what table should i modify first or should i get a tac module
  2. #2 Re: stage 2 t.b. tuning help
    Sep 2013
    The t.b is a 1997-1998 with a 2001 MAF sensor i think its a zzp stage 2
  3. #3 Re: stage 2 t.b. tuning help
    You need 97-98 maf tables.
  4. #4 Re: stage 2 t.b. tuning help
    Sep 2013
    So use the 1998 t.b. with 2001 maf and 1998 maf table
  5. #5 Re: stage 2 t.b. tuning help
    How did you get a 01 maf into a 98 tb?
  6. #6 Re: stage 2 t.b. tuning help
    Not if his car is a 99+
  7. #7 Re: stage 2 t.b. tuning help
    Sep 2013
    Its a stage 2 the inlet is bored out
  8. #8 Re: stage 2 t.b. tuning help
    Sep 2013
    Its a 2001 gtp
  9. #9 Re: stage 2 t.b. tuning help
    pics of tb
  10. #10 Re: stage 2 t.b. tuning help
    Sep 2013
    I wish i took some pics it looks like the one on zzp of the stage two but its a 1998 so no epoxy was needed
  11. #11 Re: stage 2 t.b. tuning help
    Feb 2009
    flintnasty MI
    Ugg. All ported tbs are 98 style with a 99 maf...
    Go back to a stock maf file and add 25% to the whole thing and go from there.
  12. #12 Re: stage 2 t.b. tuning help
    Sep 2013
    Thanks ill try that first i was going to start fresh with a IFR yes no ???
  13. #13 Re: stage 2 t.b. tuning help
    Feb 2009
    flintnasty MI
    yes, leave your IFR where it should be... You dont really have a decent maf file to look at anymore so your IFR is going to stay put.
  14. #14 Re: stage 2 t.b. tuning help
    Sep 2013
    Thanks you are really close to what i started with using dhp and table modifier most my maf table has been 25-27% from 2000 to 6000 hertz i figured that the amouny of adj needed it is best to start with ifr but i am going to do the 25% the whole table and see how it goes
  15. #15 Re: stage 2 t.b. tuning help
    Sep 2013
    Thanks 33% increase to the maf table and now i am -5 ltft and safe pulls like craze with 50% throttle i have some adj to make and a ssic to install thanks again
  16. #16 Re: stage 2 t.b. tuning help
    Florida
    now DH finally is having someone modify their MAF....wow never thought that day would come.
  17. #17 Re: stage 2 t.b. tuning help
    Feb 2009
    flintnasty MI
    Its not required persay but when you build a maf from nothing its an option to change the curve a bit based on what you find. Fixing mechanical problems by changing the maf is still hokey.
  18. #18 Re: stage 2 t.b. tuning help
    Sep 2013
    So what are you guys saying did i make the wrong change
  19. #19 Re: stage 2 t.b. tuning help
    Arizona
    Quote Originally Posted by Z34Phoenix View Post
    ^^^this
  20. #20 Re: stage 2 t.b. tuning help
    Florida
    I completely agree with what you say here. You don't compensate for a mechanical problem with tuning. I could see in an emergency to limp home... But tuning is not a replacement for a broken or out of spec part
  1. Intense turbo cam, stage 1 or stage 2!
    By SharkBite in forum Wanted To Buy - Parts
    Last Post: 02-21-2013, 03:40 PM
  2. Stage 3 SRT
    By fratzke7 in forum Track Sessions and Kills
    Last Post: 03-19-2009, 01:48 PM
