Thread: DHP cable set up help
Results 1 to 20 of 26
  1. #1 DHP cable set up help
    ive got my hands on a DHP and Bills drop box. and for the life of me i cant get this thing to register the cable.
    i think i need some step by step direction lol
    im using a laptop running win 7, (32 bit) deleted all the new versions of .net framework, installed 1.1, the mcda 2.8, keyspand driver for win 7 & 8, its on com port 4. only ports 3 and 4 even try to load the cable. and pretty much d/l'ed the whole DHP folder form Bills drop box, un zipped and installed most of it. not sure on a few of them files tho, says remover in the exe, not sure i want that?
    ive tried to change the compatibility in DHP to every thing listed, nothing worked.
    im surprise i haven't thrown the laptop yet.
  2. #2 Re: DHP cable set up help
    If the laptop is to new it won't work. Did you dl the keyspan drivers?
  3. #3 Re: DHP cable set up help
    its not all that new, its a 32 bit system. but is supports win 7 well. yes tried a few different k/s drivers, all say its on com 4 and nothing works lol
  4. #4 Re: DHP cable set up help
    just checked the laptop date. its a 2001. yeah its not new lol
  5. #5 Re: DHP cable set up help
    Enfield, CT
  6. #6 Re: DHP cable set up help
    hp site wont help, found the software page already, plus i have bills drop box thats full of stuff.
  7. #7 Re: DHP cable set up help
    i won!!!
    turns out i had to go into device manger and set the speed to the slower speed of 56,000 and then in dhp. synced right up.
    now i need to figure out how to set stuff to not report.
  8. #8 Re: DHP cable set up help
    That part is easy
  9. #9 Re: DHP cable set up help
    oh, yeah? i just scared the crap out of my self. damn pc crashed while reading the pcm, then the car would not start up!!!!
    off on a few times, opened the door, beep the horn, then it fired up. got the lappy up and running again scanned it and it had a security code......oh boy.
    im cooking dinner and try again.
  10. #10 Re: DHP cable set up help
    well i cant read my pcm. the damn pc crashes anywhere from 1/2 to 3/4 complete. dont know why.......
    am i missing a down load or something in the software?
  11. #11 Re: DHP cable set up help
    Can you change the speed the DH reads the computer??
    I've seen it on HPT where reading it in high speed can fail, but switching to low speed reading makes it work.
  12. #12 Re: DHP cable set up help
    thats how its set up, slow speed on the comm ports, when it was on hi speed it refused to register the cable.
  13. #13 Re: DHP cable set up help
    oh. i did switch both back to hi speed and it flat out refused to read the pcm.
  14. #14 Re: DHP cable set up help
    gardner,mass
    Did you go into device manager and right click the device and update driver via loading specific from bills thumbdrive?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #15 Re: DHP cable set up help
    its a keyspan usb, so i got the driver off their web site.
    problem now is the damn pc keeps crashing while trying to read my pcm.
    had a deleting codes lesson with Bill this morning, so i got a new bin ready to flash now, but i cant read yet.
    im off to a friends to try a battery charger and the laptop plugged in. see if that helps. if not ill try another pc.
  16. #16 Re: DHP cable set up help
    gardner,mass
    Dont try it plugged in, ive heard horror storys of it bricking the pcm. If anything see if you can change the power setting while battery is active to performance and do all your windows updates and like i said if you havent tried updating the drivers via the device manager instead of installing them i would try that.
    Also right click on the program and run it in windows xp mode and also change is to run as administrator and see if either of those help.
  17. #17 Re: DHP cable set up help
    got it done. battery charger and a powered lap top.
  18. #18 Re: DHP cable set up help
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    You can't even set a read/write speed until the cable is synced.
    I believe your talking about baud rate which should be set to 57,600 if your firmware is 2.0 or older and 115,200 if you have the 2.2 or newer firmware.
    Once the cable has been synced you can read your pcm or flash a new bin if you have one already, the DHP automatically defaults to low speed read/write and should be left that way.
    I leave the laptop plugged in to an ac outlet even if it's battery is at full charge when reading/writing just to be on the safe side along with taking measures to ensure your car battery is sitting at more than 11.5v and preferably without anything draining battery power at this time.
    I use an old POS IBM thinkpad that has Windows 2000 on it...lol Cheap and easy as it still has a serial port so no need to deal with keyspan/drivers.
    Before you read your PCM you should run the "PCM Information" option first which is located under the menu title "PCM Flash" then your ready to read your bin and if I was you I would get a read on your stock bin then save and then edit a copy of that bin with the adjustments you want to make then let the DHP decide wether you need to do a full or partial write by setting the read/write to auto...less flash time makes for less time any errors or accidents can take place as far as losing power to your laptop or having your vehicle battery voltage drop too low.
    Good Luck Scotty!
  19. #19 Re: DHP cable set up help
    gardner,mass
    Hmm weird then why have i heard of people having problems with it plugged in, or maby thats just plugged into your car charging.
  20. #20 Re: DHP cable set up help
    as i under stand it the laptop cant be plugged into a power inverter running off the cars battery. that will brick the pcm.
    i did ask bill before doing this. seems to have been a voltage issue. cause once it was on a charger to the cars battery on trickle charge, the lap top was plugged into a cord from the house it just went to town read, then i took the file and saved it. made a copy of it. then tuned the codes out on the copied file, it up loaded pretty damn fast. fire right up too.
    oh, and no more rear o2 code. ( the o2 is no longer in the car) the egr shows ready already, ( its coming off the car) evap still has to work its tests as i only deleted the offending code from that.
    im a happy camper now
  1. Abs cable
    By jc71corvette2 in forum Brakes/Suspension/Chassis
    Last Post: 10-26-2013, 03:23 PM
  2. Detent cable Help!!
    By Maxwellsilverhammer in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-02-2011, 03:13 AM
  3. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
  4. Please help with power cable for amp
    By blazer2002 in forum General Tech Discussion
    Last Post: 06-05-2009, 05:54 PM
  5. zzp alternator cable
    By Jakegday in forum General Tech Discussion
    Last Post: 05-28-2009, 11:44 PM
