Thread: Reading MAF in Hz?
Results 1 to 10 of 10
  1. #1 Reading MAF in Hz?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Is there a cost effective way to read the MAF sensor in Hz instead of G/s or is that a fantasy without an Aeroforce? I need to give Will a full rundown of my LT fuel trims based on MAF frequency.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  2. #2 Re: Reading MAF in Hz?
    A scanner or scan gauge can do them, otherwise I have no idea how you'd be able to get the numbers.
  3. #3 Re: Reading MAF in Hz?
    Nebraska
    My torque app will only read in G/s. What kind of scanner are you talking about?
  4. #4 Re: Reading MAF in Hz?
    Arizona
    Buy HP tuners/dhp/tinytuner... do it yourself.
  5. #5 Re: Reading MAF in Hz?
    hangover park IL
    Quote Originally Posted by 94GrandPrixSE View Post
    well **** dude, all you need is yer current maf table gps vs hz and just substitute the hz for the gps value...
    ~James~ Psychotic Gearhead
  6. #6 Re: Reading MAF in Hz?
    Feb 2009
    flintnasty MI
    yep^
    You can add PID's in torque , and maybe aeroforce.... Its pretty simple.
    Code:
    PidID	DisplayName	LogName	Description	Formula	Unit	Size	PIDCode	DeviceID	Conversion	PidCat	MCI
    19	MASS AIR FLOW RAW INPUT FREQUENCY	MAF		((N1 << 8) + N2) / 2.048	Hz	2	1250	1		1	MAF
  7. #7 Re: Reading MAF in Hz?
    Feb 2009
    flintnasty MI
    the 1250 is the PID hex code. Mode 12 I believe but it might be mode 9 if thats wrong.....
  8. #8 Re: Reading MAF in Hz?
    Feb 2009
    flintnasty MI
    got bored
  9. #9 Re: Reading MAF in Hz?
    Feb 2009
    flintnasty MI
    Made a commanded AFR pid too, i love this one.
  10. #10 Re: Reading MAF in Hz?
    Nebraska
    That worked perfectly Darkhorizon Thank you very much!
  1. 98 gtp boost reading
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2017, 06:38 PM
  2. odometer reading/DIC
    By rodburner in forum General Tech Discussion
    Last Post: 06-02-2010, 09:15 PM
  3. Issue reading PCM
    By otakurx in forum General Tech Discussion
    Last Post: 02-16-2010, 08:55 PM
  4. No boost reading..
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2009, 07:53 PM
  5. MAP reading
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 12:34 AM
