I never touch add vs tps.
I only adjust add vs rpm table if needed.
You can either leave the stock PE table of 12.3-12.4 plus the ADD vs RPM to bring it down to 11-11.5 afr or you can zero out the adder and set PE to 11.4 all way across. Having a wideband can help make sure you are really seeing that.
The stock tune already runs it slightly rich, so you really don't have to mess with it much. Unless you start seeing problems.
