Thread: gtp pcm security question
Results 1 to 9 of 9
  1. #1 gtp pcm security question
    Dec 2012
    troll land
    Ive heard there is a couple yrs of 2nd gen gp pcms that dont need unlocked to use it on another car. 98-99 right? Thanks
  2. #2 Re: gtp pcm security question
    They arent ever locked per say, but there is just a chance that you need to do a security relearn and case relearn when installing a different pcm.
  3. #3 Re: gtp pcm security question
    Dec 2012
    troll land
    Wow that was fast! Anyway, i have a 99 gtp pcm, what do i do for a case/security relearn? Thanks.
  4. #4 Re: gtp pcm security question
    If you know someone that has a dhp or hp tuner they can do a relearn. It's 6th gen gp btw 97-03
  5. #5 Re: gtp pcm security question
    Security learn is with the key itself, if the security light is flashing. You an google the procedure.
    Case learn, aka cam and crank sensor relearn can be done with a aeroforce, hp tuners, dhp tuner and a tech 2. Maybe even a snap on modis.
  6. #6 Re: gtp pcm security question
    Dec 2012
    troll land
    Will it run without doing this if it need it done(no one close has one, would ha e tl drive a ways)
  7. #7 Re: gtp pcm security question
    Dec 2012
    troll land
    Figured out you can run a 98-99 gtp pcm without flashing as its pk2. 2000+ are pk3 so you have to relearn it. Been running a 99 gtp pcm in my l67 swapped monte 5 monthes now
  8. #8 Re: gtp pcm security question
    Feb 2009
    flintnasty MI
    I bet your airbag light is on.
  9. #9 Re: gtp pcm security question
    Dec 2012
    troll land
    Nope pulled airbag system a long time ago
  1. Security tuning question
    By GTPSHAWTY in forum PCM Tuning
    Last Post: 10-29-2013, 01:49 PM
  2. 02 GP GT Coupe Security Question???
    By 02GPinNY in forum Audio, Security & Visual Electronics
    Last Post: 08-15-2012, 06:56 PM
  3. security system question
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2011, 05:37 PM
  4. Security
    By Bob8205 in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 06:43 PM
  5. OEM Security LED
    By Lion29GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 01:47 AM
