Thread: Question on kr?
Results 1 to 3 of 3
  1. #1 Question on kr?
    Aug 2008
    SOUTH TEXAS
    I still having trouble removing kr i'm seeing after the shifts.
    Maybe like 1 or 2* then it goes away.
    My wide band reads 10.4-10.5 on wot.
    Anything i should change on my tune to try to get rid of it?
    Id tried to lower my shift points, no luck.
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Question on kr?
    you think youre running a little rich? i do.
    you should be shooting for mid-high 11s on the wideband. if youre really edgy, push it into the 12.2 range for even more power but that is just unsafe if fueling cuts out for some reason.
    what pulley are you running? might want to pulley back up. what about your WOT timing, where is that?
  3. #3 Re: Question on kr?
    Aug 2008
    SOUTH TEXAS
    I ran on the 3.2" at the track.
    For one of the runs i put the 3.4 back still the same kr showed up.
    Timing, i think it was stock still.
