Thread: PCM E85 cranking fueling questions
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #41 Re: PCM E85 cranking fueling questions
    Arizona
    So why don't. You email them? They'll add stuff especially when the code is already there.
  2. #42 Re: PCM E85 cranking fueling questions
    Feb 2009
    flintnasty MI
    Sell hpt buy dhp. Problem solved
  3. #43 Re: PCM E85 cranking fueling questions
    Arizona
    Just cause you had a bad experience and we're unable to successfully flash dose t mean the other tens of thousands people will. Hpt support is actually quite good. Theyve always got all my requests handled
  4. #44 Re: PCM E85 cranking fueling questions
    May 2008
    Schuyler, NE
    DHP sucks. The only time I ever use mine is when I need a bin.
    It would be nice if HPT gave us more tables, but at least the program reads bin files. It would be much more inconvenient if they limited it to hpt files.
  5. #45 Re: PCM E85 cranking fueling questions
    Aug 2011
    colorado
    Frosty- til you can find the crank fueling tables, look for crank spark tables in HPT and try adding it in increments of 5 and see if it helps. My car started a little better after adding fuel but adding spark at startup made more of a noticeable difference IMO. something to try in the meantime
  6. #46 Re: PCM E85 cranking fueling questions
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Reread the thread. I found the table and successfully modified it. Car starts effortlessly now. Cranking timing wasn't touched. Only fuel.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  7. #47 Re: PCM E85 cranking fueling questions
    Apr 2011
    South Dakota
    Also hpt has zero access to any cranking tables so I used a bin file and tiny tuner.
    I love Decker<3
  8. #48 Re: PCM E85 cranking fueling questions
    hangover park IL
    dhp/tiny/uvscan > hpt
    ~James~ Psychotic Gearhead
  9. #49 Re: PCM E85 cranking fueling questions
    hangover park IL
    Quote Originally Posted by 91parkave View Post
    thos ****s wont do anything, youd get farther hiring a buncha coding zip heads and make a new OS with huge tables and a god damn 3 bar setup...or just go Mega squirt
  10. #50 Re: PCM E85 cranking fueling questions
    May 2008
    Schuyler, NE
    Quote Originally Posted by Turbocharged400sbc View Post
    Until this happens.
    http://www.clubgp.com/newforum/tm.as...de=&s=#4077898
  11. #51 Re: PCM E85 cranking fueling questions
    Feb 2009
    flintnasty MI
    You can brick a pcm with hpt just as easily.
  12. #52 Re: PCM E85 cranking fueling questions
    May 2008
    Schuyler, NE
    I've never done it, and I've tuned far more vehicles with HPT than DHP.
  13. #53 Re: PCM E85 cranking fueling questions
    i only bricked one pcm so far, but the laptop crashed while writing. and that caused it.
  14. #54 Re: PCM E85 cranking fueling questions
    Apr 2011
    South Dakota
    I have had a few scares on mine. Laptop shutting down or other whatnot. HPT always was able to recover it. Adeckers car has some major can bus issues and his has to do a recovery flash every 5 flashes it seems like.
    I love Decker<3
  15. #55 Re: PCM E85 cranking fueling questions
    Arizona
    I had a blue screen of death while flashing, however all it took was a battery unplug for a hour or two and a re flash and everything was good.
  16. #56 Re: PCM E85 cranking fueling questions
    maybe i should try that with my old pcm. its been sitting un powered for months now lol
  17. #57 Re: PCM E85 cranking fueling questions
    Feb 2009
    flintnasty MI
    Over 1500 flashes on dhp and zero bricked pcms.
  18. #58 Re: PCM E85 cranking fueling questions
    hangover park IL
    2 bricks here with dhp
    1st was someone shutting the ign switch off by habit while getting out of their car...after it lobotomized the pcm and started writing. FUuuuuu
    2nd was the 04+ as i was trying to see where the pcm voltage limit is (aka 04+ can brick a pcm quite easily if ign voltage isnt over 11.5...so i built an offboard)
    ive been able to flash 7440's down to 10 volts without issue
  19. #59 Re: PCM E85 cranking fueling questions
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    2 bricked PCM's here with DHP.
  1. Question about my fueling
    By shawnschuldt in forum PCM Tuning
    Last Post: 08-18-2012, 05:02 PM
  2. Fueling issue?
    By dmahlikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2012, 12:57 PM
  3. Fueling
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-11-2011, 08:22 AM
  4. over fueling?
    By savannaz34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 02:23 AM
  5. '04 GP GT - 2 Questions, Fueling and start up related.
    By Ryan04GPGT in forum General Tech Discussion
    Last Post: 03-19-2009, 04:16 PM
