Thread: Parameters to look at on torque app
Results 1 to 8 of 8
K Kraziee Parameters to look at on... 11-01-2013, 07:39 AM
cmal37 Re: Parameters to look at on... 11-01-2013, 08:43 AM
K Kraziee Re: Parameters to look at on... 11-01-2013, 10:19 AM
cmal37 Re: Parameters to look at on... 11-01-2013, 10:29 AM
Fivefingerdeathpunch Re: Parameters to look at on... 11-01-2013, 10:40 AM
K Kraziee Re: Parameters to look at on... 11-01-2013, 11:34 AM
nos4blood70 Re: Parameters to look at on... 11-01-2013, 02:43 PM
dsmuts Re: Parameters to look at on... 11-01-2013, 04:57 PM
  1. #1 Parameters to look at on torque app
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I know that boost/vacuum and KR are a must, but what else do you guy's look at while daily driving?
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Parameters to look at on torque app
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I have fuel trims, engine and trans temp, percent throttle, IAT temp, AFR, and timing. Then I have a whole spark plug page, for current and history of missfires
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  3. #3 Re: Parameters to look at on torque app
    Apr 2013
    Milwaukee
    Nice, I tried logging afr but it wouldn't let me do i need a wideband connected? Also it seem's like I can't get a lot of parameter's that other's can get like Trans Temp, AFR, Oil pressure, and Oil temp among other's. I do have a tuned pcm if that makes any difference.
  4. #4 Re: Parameters to look at on torque app
    May 2011
    Tampa FL near USF
    did you go to settings and set it to the GM settings?
    Settings>Manage extra PIDs/Sensors> Add Predefined Set> Pontiac/GM/Opel/Vauxhall
    That should load all the sensors associated with the car so you can monitor pretty much everything. Some things dont work. I couldnt get oil pressure to work
  5. #5 Re: Parameters to look at on torque app
    Air fuel ratio/lambda readings would need to come from an actual gauge for a wideband/lambda sensor. A phone app can't do that.
    And our cars couldnt read oil pressure either as its only got a dummy light, not a real sensor for reading psi.
  6. #6 Re: Parameters to look at on torque app
    Apr 2013
    Milwaukee
    ugh that's lame considering oil pressure it pretty important. I'll try the GM setting and see where that gets me.
  7. #7 Re: Parameters to look at on torque app
    Jul 2012
    Chicago
    My Bonneville reads oil pressure. In any case, I have coolant/trans temp, IAT, KR and some other stuff. Battery voltage.
    -Carl
  8. #8 Re: Parameters to look at on torque app
    bonnevilles got a real sensor.
  1. Replies: 9
    Last Post: 09-13-2012, 01:55 AM
  2. Engine parameters
    By SarasotaGTP in forum General Tech Discussion
    Last Post: 02-01-2012, 08:22 AM
  3. which parameters to run on aeroforce?
    By z3r0 in forum General Tech Discussion
    Last Post: 11-14-2011, 11:43 PM
  4. scan parameters
    By sca555 in forum General Tech Discussion
    Last Post: 03-19-2011, 01:12 PM
  5. Why cant I see parameters
    By deangtp in forum PCM Tuning
    Last Post: 04-14-2008, 06:03 PM
