How much kr? Do you have a wide band? Of so what is the af? Does it go lean toward the end of the shift? If no wb scan commanded af and O2 voltage. If you see the af go leaner or voltage go down then you may just need to add fuel. You can use the pe_vs_time to increase fuel at the upper rpm and later in time to compensate.
