Thread: Unlocking a pcm with dhp
Results 1 to 7 of 7
  1. #1 Unlocking a pcm with dhp
    Some pcm's I can tune without any problem and some won't let me touch them and when I try to write a file to that pcm it says that the file isn't compatible. What am I doing wrong and what do I need to do to fix it?
  2. #2 Re: Unlocking a pcm with dhp
    Apr 2011
    Vassar, Mi
    I just started running into something similar to this with my DHP recently also. I have tuned multiple GT/GTP's a 03 SSEI, a 02 Monte SS a few 3.1L Malibus even. Never a problem, tried downloading a tune from a 01 SSEI I get a "unsupported PCM" message. 3 days later I went to turn security off on a 00 Impala with a L36 and it says "unsupported" again. I figured I could probably just tune a supported base file out of the database and upload it onto the PCM over the unsupported file. Neither car was actually at the shop though and I don't want to try it for the first time on someone elses PCM and end up bricking it.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: Unlocking a pcm with dhp
    Feb 2009
    flintnasty MI
    need more info.. alot more.
  4. #4 Re: Unlocking a pcm with dhp
    What do you need to know. I can take screen shots tomorrow
  5. #5 Re: Unlocking a pcm with dhp
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Shoot me a copy of that file.
    Rivman@gmail.com
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  6. #6 Re: Unlocking a pcm with dhp
    Florida
    the DHP only supports the newest OSID's for each year make model trim. if the car never had the pcm updated from the dealer and has an early OSID the tuner will reject the file. You can use the cars VIN to check the correct OSID for it. http://tis2web.service.gm.com/tis2web then if you have that OSID, just do a full write over top of the existing file.
  7. #7 Re: Unlocking a pcm with dhp
    If you need the bins that DHP supports plus the rest of the crap I have. Send me your email and I'll link you to dropbox where I have all this stuff.
  1. The fuse for locking / unlocking doors keeps burning, think i have a short HELP!!!
    By Fernando Estrada in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2013, 04:42 PM
  2. 2000 3.8 gt toruqe converter locking and unlocking
    By jbanderson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2012, 08:21 PM
  3. Car self unlocking
    By trucker2020 in forum General Tech Discussion
    Last Post: 03-22-2011, 01:34 AM
  4. unlocking lock screen for iphone.
    By tazyboy28 in forum Off Topic Discussion
    Last Post: 05-10-2010, 12:29 AM
  5. Lock-up not unlocking
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 02:23 PM
