MAP sensors are used for more then a MAF can tell you.
One example, Injectors will flow less fuel as boost increases (Pressure differential between the Fuel Rail and Manifold decreases). The ECU will increase IPW to compensate.
I write engine control software for a living, it's easy to make an engine run ok under most conditions, it's tough to make it run right under all conditions.
-Rob
