Thread: How to get around P0420 code?
Results 1 to 10 of 10
  1. #1 How to get around P0420 code?
    Florida
    A few weeks ago I had my boy in Orlando temporarily lightly tune my car and one of the things he did was delete my cat code p0420 so I could get rid of the check engine light. Since then my gas mileage has dropped some and my boy explained to me doing that threw my fuel trims off which seems correct. So on Friday I plan to go back and get a full tune from him and he said he will probably just turn the code back on but before he does that is there anyway around having my check engine light on while having the code open so my mileage goes back up?
  2. #2 Re: How to get around P0420 code?
    You can try moving the o2 sensor farther away or do the spark plug non fouler trick, it might work.
    Read on the 01+ thread about removing the rear o2, will likely have more info on what to do.
  3. #3 Re: How to get around P0420 code?
    Florida
    I saw that thread but didnt exactly thoroughly look thru.it,just saw that 01+ cars go thru the issue. I also forgot about the non fouler. What would moving the o2 further away do?
  4. #4 Re: How to get around P0420 code?
    SWPA
    Moving the o2 further back acts just like a non fouler.
    I have a high flow cat on a ZZP downpipe and the optional "non fouler" built in and have non CEL.
  5. #5 Re: How to get around P0420 code?
    Feb 2009
    flintnasty MI
    04s do not suffer as that much from the cat test modes that the 01-03s did.
  6. #6 Re: How to get around P0420 code?
    Florida
    Well sadly i fall into that group lol.
  7. #7 Re: How to get around P0420 code?
    I'm not running a rear o2 at all. Tuned the code out and all is well. I notice every now and again it'll do the cat test I think the afr will richen to ~12 for about 10-20 seconds then go back to normal
  8. #8 Re: How to get around P0420 code?
    I would just go with the non fouler, its the cheepest option and it works.
  9. #9 Re: How to get around P0420 code?
    Use the non fouler trick..never had the p0420 trip on me with it.
    04 Comp G.
  10. #10 Re: How to get around P0420 code?
    Florida
    Ill look up that non fouler trick and give it a shot. Ill let my boy know to leave the code deleted for now.
  1. P0420 code
    By parsonsl1 in forum Introductions/Noob Questions
    Last Post: 11-01-2012, 09:53 AM
  2. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  3. code p0420?
    By Jtg1551 in forum General Grand Prix Discussion
    Last Post: 09-07-2012, 11:58 AM
  4. P0420 code
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2010, 03:25 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
