Thread: Unable to locate vcm with hpt
Results 1 to 4 of 4
  1. #1 Unable to locate vcm with hpt
    Aug 2013
    Kitimat, B.C.
    I had this problem a few weeks ago after a few times hooking up the pcm with hpt. Couldn't figure it out so I pulled all wires from the pcm connectors to tidy everything up and re hook it all back up and everything worked fine. The other day I took out the coilpack/icm to remount it and since then I get the error "unable to locate vcm. verify the cable is connected and the key is in the run position." This 3800sc swap is in a fiero that I have yet to fire up.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Unable to locate vcm with hpt
    Well whatever you did stopped the communication to the PCM.
    So some connection isnt being completed and now the obd 2 can't locate the PCM.
  3. #3 Re: Unable to locate vcm with hpt
    Arizona
    Sometimes a battery disconnect overnight can solve the issue
  4. #4 Re: Unable to locate vcm with hpt
    Aug 2013
    Kitimat, B.C.
    I was playing with the ignition cylinder lock and I think it's in there. Not sure if I need to replace the whole cylinder or if there's a loose wire in there. When I put the key to run then start, it's at the very end of the stroke before contact is made to start.
  1. Trying to locate the grind.
    By Bluemagic in forum General Tech Discussion
    Last Post: 07-15-2013, 12:12 PM
  2. Unable to remove key from the ignition.... intermittently.
    By ronmexico in forum General Tech Discussion
    Last Post: 04-13-2012, 03:07 PM
  3. unable to post pictures
    By 99GPGTP in forum Off Topic Discussion
    Last Post: 07-14-2011, 09:10 PM
  4. Unable to peelout
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 07-06-2010, 10:34 PM
  5. Help!! Unable to CASE Learn
    By jamster00 in forum General Tech Discussion
    Last Post: 06-18-2009, 09:06 PM
