Thread: 87 vs 93 NA tune
Results 1 to 14 of 14
  1. #1 87 vs 93 NA tune
    Jul 2012
    Chicago
    I'm having what's basically an in car tune and I was wondering how big of a difference is 93 gonna make on the L36 once the timing is set up for it? I have a mildly ported stock front manifold. A ported lower intake manifold and an FWI.
    What are guys' experiences? Also how about fuel economy?
    Thanks
    *EDIT* Also, is it possible to do a CASE learn with HPT?
    -Carl
  2. #2 Re: 87 vs 93 NA tune
    Yes a case learn can be done with HPT.
    93 is better than 87 for helping with KR. You fuel mileage will not really change by using a higher grade fuel.
  3. #3 Re: 87 vs 93 NA tune
    Jul 2012
    Chicago
    What about like a butt dyno difference between the two?
    -Carl
  4. #4 Re: 87 vs 93 NA tune
    SWPA
    Octane doesn't increase HP. Octane is only a knock preventer.
  5. #5 Re: 87 vs 93 NA tune
    You can make more power up to 27* of timing.
    After that, run lower and lower octane. It'll apparently drive better.
    Look at the ethanol content in your fuel rather than the octane rating.
    And a NA tune is pointless unless you're unhappy with the transmission settings.
  6. #6 Re: 87 vs 93 NA tune
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I got a 91 incar tune from overkill and I felt way more from the tune then any other mods I have done so far.
  7. #7 Re: 87 vs 93 NA tune
    Banned
    CT
    Quote Originally Posted by nos4blood70 View Post
    Thanks
    Unfortunately you won't gain too much power with a 93 octane tune on the L36. Maybe 5-10whp though.
    The tune would be more effective at changing shift points/settings and bumping cruise timing for slightly better mileage.
    Also deleting any codes you may not need anymore.
    Yes HPT does case learns, and so does DHP.
  8. #8 Re: 87 vs 93 NA tune
    Jul 2012
    Chicago
    Thanks for the advice guys. I'll update you once stuff goes down.
    -Carl
  9. #9 Re: 87 vs 93 NA tune
    St Thomas Ontario
    So how do you like the tune?
  10. #10 Re: 87 vs 93 NA tune
    Florida
    When I was NA I did both a 87 and 93 tune. The engine did not respond to additional timing at all. My DOHC LQ1 loved 93 and I was able to add lots more timing with it. My 14.9 track time was on 87! I also had intake, HV3, and headers. Just stick to 87 and save the $3-5 per fill up towards other mods.
  11. #11 Re: 87 vs 93 NA tune
    Jul 2012
    Chicago
    To the average person there isn't much of a difference. I feel that it pulls a little harder in the mid range. Will said he was able to add a couple degrees on the 93. Whether there is a true difference or it is just my butt dyno, I guess I'll never know. I'm currently running on the 87 but I can switch at any time as long as I have my laptop(which is almost always.) NA is cool and all and I guess for an NA she boogies pretty good considering it's an H-body. But I purchased a turbo kit a couple weeks ago. So that's happening this Spring most likely.
    -Carl
  12. #12 Re: 87 vs 93 NA tune
    St Thomas Ontario
    Righton I love my overkill tune.
    Goodluck on turbo
  13. #13 Re: 87 vs 93 NA tune
    Jul 2012
    Chicago
    Thanks. Can't wait for the trollz. I'm gonna try and self tune the turbo set up. Just going for low boost until I can build the trans over summer sometime.
    But to conclude. Most people say NA tunes aren't worth it. I don't know. Overkill did an amazing job for me. Even on 87 it is spunkier than it used to be. Gets about 2 MPGs more. And the trans is a new animal. So much smoother and more refined feel. I'd say go for it, if anyone were asking me.
    -Carl
  14. #14 Re: 87 vs 93 NA tune
    St Thomas Ontario
    out of all my mods, the incar tune is what i noticed most. headers secondly
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. tune?
    By RICE KILLER in forum PCM Tuning
    Last Post: 03-10-2010, 04:00 PM
