Thread: noob tuner - need some help
Results 1 to 20 of 22
  1. #1 noob tuner - need some help
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Hey all,
    First question - I'm using a 00 GP GT sedan body with a 00 GTP engine/trans...
    Everytime I scan my wot's for tuning I get a p1260 code, which is the (fuel pump speed control relay). The GT doesn't have this relay in the under-hood fuse/relay panel.
    I set the code to "no error reported" but I'm wondering if there is a way to keep the fuel pump in high speed? I don't know where/if there is even a relay for the speed
    control on the GT body... any advice here is greatly appreciated.
    Second question - while scanning wot's, my maf table get wacky! I'm trying to get into mid 11's afr on the 7k rpm and higher cells but when I adjust the table it stays in
    13-14 afr... no matter what I do! Could this be a fueling issue?
    My mods are:
    rebuilt and bored block, 3.0 pulley, heads, headers, XP cam, CAI, ported blower/TB/Lim.
    Thanks in advance
    Edit: Just ordered a Racetronix Hi-flow venturi fuel pump.
    Edit #2: afr gets into mid 11's after about 8250k cell.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: noob tuner - need some help
    May 2008
    Schuyler, NE
    Can you upload tune files on this forum? If so, upload your current tune.
  3. #3 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    Will do. Entire file or images?
  4. #4 Re: noob tuner - need some help
    On the code. No error reported and no check mark. Your pump is always in high speed being a GT
    I didn't realize you were a GT. That's why the code was kicking. It definately wasn't the pulley
  5. #5 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    My bad bill. Thought I specified a GT model :/
    Do you think I should do injectors with the 3.0. I can't seem to get enough fuel during wot scans. I will post pics when I get home.
  6. #6 Re: noob tuner - need some help
    Well are your injectors going static?
    Like running over 100%?
  7. #7 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    The max I've seen them during WOT was 88%
  8. #8 Re: noob tuner - need some help
    This is a part I don't understand, I am still kinda new to tuning, but I am unsure which way you are going at this.
    I just left the MAF table 100% stock past 7,000hz and changed my commanded afr to 11.5 and got rid of any adders that would change it. I set PE to 35% re did the timing tables to 16* for the last 3 "cells". Thats just a cut and dry of what I did, there is alot more to it.
  9. #9 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    I was following "starting hp tuners" thread by "theothernick". It primarily focuses on 7k cells and above. Would you be able to send me your tune file so I can look at it? What are your current mods?
  10. #10 Re: noob tuner - need some help
    May 2008
    Schuyler, NE
    Post the whole file.
  11. #11 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    Haven't changed much. Only idle, fans and maf. Still stuck trying to figure out the maf. I'm upping from a 3.0 to 3.4 and putting in a racetronix fuel pump tomorrow. We'll see if that makes a difference.
  12. #12 Re: noob tuner - need some help
    Feb 2009
    flintnasty MI
    you should be scanning commanded AFR and throttle position to be able to tell what the PCM is commanding. Your Power enrichment is what tells the motor to start going rich, and that is enabled by a few different things.
  13. #13 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    I watch the tps all the time. As far as commanded AFR, you mean make a histogram or is one already made?
  14. #14 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    I have PE set to 30% across the board btw.
  15. #15 Re: noob tuner - need some help
    Commanded AFR is the "Base AFR vs ECT".
  16. #16 Re: noob tuner - need some help
    Feb 2009
    flintnasty MI
    1 of the few tables that modify it...
    You need to SCAN the value, its commonly refered to as Low Res AFR or something in HPT.
  17. #17 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    Thanks ffdp.
  18. #18 Re: noob tuner - need some help
    I coulda gone farther in detail, but thats where you will set the number you want and change a few other tables to get it around that.
  19. #19 Re: noob tuner - need some help
    Oct 2012
    New Jersey
    More detail is always welcome
  20. #20 Re: noob tuner - need some help
    May 2008
    Schuyler, NE
    Scan this. You probably only have the option to scan one of the PID's.
  1. Noob tuner - ltft question
    By L67PWR in forum PCM Tuning
    Last Post: 05-04-2013, 10:07 AM
  2. Hp tuner noob question?
    By Quarterpastgone in forum PCM Tuning
    Last Post: 11-12-2012, 10:24 AM
  3. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
  4. noob
    By SWHAF in forum Introductions/Noob Questions
    Last Post: 08-05-2011, 12:05 PM
  5. another noob
    By 06dmax in forum Introductions/Noob Questions
    Last Post: 10-23-2009, 06:41 PM
