This is a part I don't understand, I am still kinda new to tuning, but I am unsure which way you are going at this.Second question - while scanning wot's, my maf table get wacky! I'm trying to get into mid 11's afr on the 7k rpm and higher cells but when I adjust the table it stays in
13-14 afr... no matter what I do! Could this be a fueling issue?
I just left the MAF table 100% stock past 7,000hz and changed my commanded afr to 11.5 and got rid of any adders that would change it. I set PE to 35% re did the timing tables to 16* for the last 3 "cells". Thats just a cut and dry of what I did, there is alot more to it.
