Thread: Upping line pressures with dhp
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    Which ones are you wanting? Part throttle or WOT?
    08 G8 GT - exhaust Tune
  2. #22 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    I also have TQ managment removed which helped it shift really firm but do that knowing you could break hard parts
  3. #23 Re: Upping line pressures with dhp
    What did you change in the tq managment? wot shift points is what i'm looking for.
  4. #24 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    I have all torque management removed but you can scale it back 50% if you want to keep some of it
  5. #25 Re: Upping line pressures with dhp
    What tables do you change to do that?
  6. #26 Re: Upping line pressures with dhp
    Jul 2012
    Chicago
    This is what I need too. I'm running out of teeth from these bang shifts. It's annoying to have to let off every time the car shifts with more than a quarter throttle applied. Feels like driving stick.
    -Carl
  7. #27 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    I use HPT so it might be diff but in mine it is called Torque Reduction
  8. #28 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    For a stock trans might shifts very fast and very firm...at WOT from 1st to 2nd will chirp the tires!
  9. #29 Re: Upping line pressures with dhp
    Jul 2012
    Chicago
    Quote Originally Posted by wa04compg View Post
    Same... I don't know how comfortable I feel with that happening in terms of the life of the trans.
    -Carl
  10. #30 Re: Upping line pressures with dhp
    My gtp had 230k in the stock trans chirping tires into 2nd daily
  11. #31 Re: Upping line pressures with dhp
    Oct 2011
    Puyallup WA
    Hence why I said it can break hard parts...zzp tune has all torque management removed if I remember correctly
  12. #32 Re: Upping line pressures with dhp
    Jan 1970
    Maquoketa, Iowa
    If you have a built trans, some pressures are already raised depending on who builds it. Mine chirps 1-2nd just cruising... lol
  13. #33 Re: Upping line pressures with dhp
    Apr 2011
    Tally, FL
    Do u lose mpg if you change the normal settings similar to performance shift?
  14. #34 Re: Upping line pressures with dhp
    Shouldn't lose any mpg all
  1. Which Oil line is this?
    By Wakeboy1337 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-26-2011, 09:28 AM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. AUX / Line In ?
    By vonlupe in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2010, 03:32 AM
  4. where does this vac line go?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 01:40 PM
  5. Transmission operating pressures
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2008, 10:35 PM
