Thread: WOT Tuning....
Results 1 to 9 of 9
  1. #1 WOT Tuning....
    May 2012
    Albuquerque, NM
    What table do I use while WOT tuning. My AF goes <10 at WOT. Do I use the PE fuel% increase table? Just curious as my LT and ST FT's are about good.
    TIA guys
    Slim
    2003 Chevy Inpala LS 3.8 l36, Stattama Turbo kit, P&P LIM, P&P heads, lS7 lifters, Intense Xtreme 7.05 oil restricted pushrods, ZZP 1.9 modded rockers, 3" no cat down pipe, poly mount all around, fuel rewire, alt volt booster, and still working on it...
  2. #2 Re: WOT Tuning....
    IF you are seeing sub 10 AFR, you need to remove fuel. Either from the MAF or the PE table. Set PE to like 11.0 to 11.5.
    Otherwise you have to see what the car is doing at WOT and adjust from there. Likely you will just touch the timing tables if you see knock or what to increase timing with no knock.
  3. #3 Re: WOT Tuning....
    May 2012
    Albuquerque, NM
    No knock, PE set to 11.5, PE set to increase fuel by 150%, MAF table is good until PE kicks in. Goes from 14.7 (+/- .2) to 10 on my WB.
    Is it the percentage table? I guess I'm asking if I pull fuel using the PE percentage table?
  4. #4 Re: WOT Tuning....
    I use HP tuners to tune, so I have no idea what you are talking about. Must be a DHP thing or something.
    Why would you have PE set to 11.5 but then tell it to add 150% more fuel?? That will just wash cylinder walls and kill it. I bet the IDC is pegged lol.
  5. #5 Re: WOT Tuning....
    May 2012
    Albuquerque, NM
    DHP has two adjustments. I'll experiment....
    thanks for for the quick response
  6. #6 Re: WOT Tuning....
    May 2012
    Albuquerque, NM
    Sorry, I realized I was thinking of the acceleration enrichment table. What role does that play?
  7. #7 Re: WOT Tuning....
    Feb 2009
    flintnasty MI
    Ae effectively does nothing. Pe is your main spot to do wot fueling changes but if you have a custom maf setup then you may need to help pe by making changes to ifr or maf table.
  8. #8 Re: WOT Tuning....
    NY
    Sounds like your maf tables are off or your not commanding the correct PE.
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  9. #9 Re: WOT Tuning....
    Banned
    CT
    I bet you have bigger injectors and never set the IFR tables correctly.
    Start there.
  1. pcm tuning!
    By gunsn88 in forum PCM Tuning
    Last Post: 10-15-2011, 02:58 PM
  2. Tuning Help!
    By Kejross in forum Southwest
    Last Post: 03-15-2011, 11:45 PM
  3. tuning in BC
    By sugaryuk in forum Canada
    Last Post: 12-19-2010, 09:14 PM
  4. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
