Thread: Power tuner issue...basic problem or my own stupidity?!
Results 1 to 20 of 27
slimguns Power tuner issue...basic... 03-17-2013, 04:42 PM
darkhorizon Re: Power tuner issue...basic... 03-17-2013, 10:08 PM
slimguns Re: Power tuner issue...basic... 03-18-2013, 03:47 PM
Anthony Smith Re: Power tuner issue...basic... 03-19-2013, 11:30 AM
slimguns Re: Power tuner issue...basic... 03-19-2013, 03:34 PM
darkhorizon Re: Power tuner issue...basic... 03-19-2013, 10:19 PM
Fivefingerdeathpunch Re: Power tuner issue...basic... 03-19-2013, 10:20 PM
BillBoost37 Re: Power tuner issue...basic... 03-20-2013, 07:00 AM
Anthony Smith Re: Power tuner issue...basic... 03-20-2013, 09:46 AM
darkhorizon Re: Power tuner issue...basic... 03-20-2013, 11:05 AM
slimguns Re: Power tuner issue...basic... 03-20-2013, 05:45 PM
Z34Phoenix Re: Power tuner issue...basic... 03-21-2013, 08:08 AM
BillBoost37 Re: Power tuner issue...basic... 03-21-2013, 08:39 AM
darkhorizon Re: Power tuner issue...basic... 03-21-2013, 04:18 PM
rperry435 Re: Power tuner issue...basic... 03-21-2013, 04:40 PM
slimguns Re: Power tuner issue...basic... 03-21-2013, 09:28 PM
slimguns Re: Power tuner issue...basic... 03-21-2013, 09:10 PM
slimguns Re: Power tuner issue...basic... 03-26-2013, 05:51 PM
FoSHO99 Re: Power tuner issue...basic... 03-26-2013, 06:39 PM
slimguns Re: Power tuner issue...basic... 03-26-2013, 08:22 PM
rperry435 Re: Power tuner issue...basic... 03-26-2013, 08:54 PM
rperry435 Re: Power tuner issue...basic... 03-26-2013, 08:56 PM
slimguns Re: Power tuner issue...basic... 03-26-2013, 09:52 PM
slimguns Re: Power tuner issue...basic... 03-26-2013, 09:56 PM
slimguns Re: Power tuner issue...basic... 03-28-2013, 09:14 PM
slimguns Re: Power tuner issue...basic... 03-28-2013, 10:53 PM
slimguns Re: Power tuner issue...basic... 03-28-2013, 11:32 PM
  1. #1 Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Any idea why my PCM wouldn't take an upload? I obtained my first read, modified fans/coolant only, uploaded to PCM, re-read to make sure it took. Second read states the modified temps but my scanner and fans (actions of vehicle) states that factory settings are still in charge. Ie. fans kicking on at 212 (factory setting). I even left vehicle with no batter/power over night.
    Am I missing something. I hope I'm just missing a stupid easy step or something. Thanks for any help.
    Thanks,
    Slimguns
  2. #2 Re: Power tuner issue...basic problem or my own stupidity?!
    Feb 2009
    flintnasty MI
    Not missing anything... I would just make sure that you flashed the right file with your changes first... I have flashed over 1000 times and never had it "not take" like that.
  3. #3 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Hum? Yeah, I'll double check but I'm sure I did. Do I need to do a "full" flash the first or any subsequent attempts?
    I attempted an upload today and disconnected my battery after while I'm at work. We'll see. I'm hoping I just made a stupid mistake a few days ago.
    Thanks for your help.
  4. #4 Re: Power tuner issue...basic problem or my own stupidity?!
    Apr 2011
    Vassar, Mi
    Same here, Ive had a few weird issues with upload failure and "unsupported file" etc. Never a "successful upload" but were the file I uploaded changed in the ECU or didnt work. Also, why are you disconnecting the batt. after uploading?
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  5. #5 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Battery thing was to reset fuel trims because I didn't trust the tuner to do it after the temp not taking.
    The tuner is uploading as far as I can tell. I even read it last night and it states my modified temps but I was monitoring it and the fans kicked on at 212 and off at 208. That's stock.
    I'll try a full write tonight for the first time. I'm hoping it just needs a full write and then partials after that. I'm still open to suggestions.
    Thanks in advance y'all!
  6. #6 Re: Power tuner issue...basic problem or my own stupidity?!
    Feb 2009
    flintnasty MI
    Dont do a full. Its risky and wont solve this "problem"
  7. #7 Re: Power tuner issue...basic problem or my own stupidity?!
    Does DHP have a "write calibration only" option?
    Because that all I have to do with my HPT.
  8. #8 Re: Power tuner issue...basic problem or my own stupidity?!
    Interesting to hear that Scott. I only do full writes on DHP.
    Cam, yes it does.
    If you guys need supported bins etc. Send me a pm with your email, I'll hook you up. Thanks to Scott and a couple years of bin whoring, I think I have almost every DHP supported bin.
  9. #9 Re: Power tuner issue...basic problem or my own stupidity?!
    Apr 2011
    Vassar, Mi
    what fan settings are you adjusting anyway? You should be in fan_1_coolant_temp, and your high turn on setting should be somewhere between 71 and 82*c depending on your T-stat. Also are you sure your primary fan works and your not hearing fan 2 kicking on at the stock 108*c setting?
  10. #10 Re: Power tuner issue...basic problem or my own stupidity?!
    Feb 2009
    flintnasty MI
    full writes are only used when switching operating systems or something. If you are updating anything else a partial write is all that is needed. The operating system is stored on the bulk of the memory, a small part holds constants.
  11. #11 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    Fan_1_coolant_temp and number two are the lines being changed. As for fan one or two coming on, both the left and right fans kick on right at 212* ferenheight per my Torque app. The fans are a high low set up not a left and right set up, right? I just want to be sure I'm expecting to see/feel the right stimuli.I was advised to try to type in my VIN as the guy had some issue similar to mine in the past and manually entering helped. I sure hope it does. The last thing I want is to be stuck with one tune for EVERY situation/season.
  12. #12 Re: Power tuner issue...basic problem or my own stupidity?!
    Florida
    the vin wont shouldn't have anything to do with it not using the settings if there was a vin conflict it wouldn't start. lets start from the basics.
    What year make model do you have? and osid of the bin or upload/link to the bin if possible.
    What specific lines are you changing in the bin? screen shot or type word for word the table your changing.
    I to have never had an issue where i successfully uploaded a bin and a setting not transfer. Are your fans set up correctly? IE are both fans connected in the stock configuration or has someone before you or yourself rewired them to operate at the same time? before i had a tuner i ran my 2nd fan off a relay connected to the first. but with the tuner i no longer needed to do this and set it all back to stock
  13. #13 Re: Power tuner issue...basic problem or my own stupidity?!
    Scott.. where's that PCM number chart you've posted before?
  14. #14 Re: Power tuner issue...basic problem or my own stupidity?!
    Feb 2009
    flintnasty MI
    ClubGP Message Forum troubleshooting
    Everything is there. I keep it there because I always update that post with new bits.
  15. #15 Re: Power tuner issue...basic problem or my own stupidity?!
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I always write entire but I assume that's just hpt
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  16. #16 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    If my last post doesn't change the situation I will post a step by step with pictures.
  17. #17 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    So, tonight I "read" my PCM. The first clue was my VIN had lower case text in it. At that que, I checked the rest of the calibration file and the file is identical to my scan I uploaded. What a concept?! I mentioned this in my first post that the temps seem to have uploaded.
    What else could cause the difference? Do the fans function on a high/low type switch or is it actually a fan 1 and fan 2 type switch?
    TIA
  18. #18 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    I have followed the instructions to the T. My next thought was about the aftermarket alarm that was installed. It controls the locks, trunk, and auto start. I went back to Best Buy and he said it "should" be "t'd" off the data line and therefore shouldn't effect this. Question, if it was improperly installed in-line in between the PCM and BCM or between the OBDII and the BCM or between the OBDII and the PCM would that effect it as the BCM controls the cooling fans? I am in process of tracking this immobilizer down under my dash to be sure it is in fact "t'd" off properly but in the mean time, what do you think?
    My theory makes sense to me. Am I too far off?
    TIA,
    Slim
  19. #19 Re: Power tuner issue...basic problem or my own stupidity?!
    Jan 1970
    Maquoketa, Iowa
    1. Upload your current modified .bin file to Free large file hosting. Send big files the easy way!
    2. Upload your last scan to Free large file hosting. Send big files the easy way!
    3. Post the links to each upload one here, we should be able to help you out much better that way.
  20. #20 Re: Power tuner issue...basic problem or my own stupidity?!
    May 2012
    Albuquerque, NM
    I'll do it tomorrow night. Stupid work...
  1. power tuner help
    By 97redrocket in forum General Tech Discussion
    Last Post: 04-07-2010, 07:39 PM
  2. DHP Power Tuner
    By 98gtpne in forum General Tech Discussion
    Last Post: 09-29-2009, 11:27 PM
  3. New power tuner
    By Deeter in forum PCM Tuning
    Last Post: 05-26-2008, 09:32 AM
