Thread: Can't get timing to match table values!??!
Results 1 to 2 of 2
  1. #1 Can't get timing to match table values!??!
    Feb 2008
    I'm working on an '05 NA Grand Prix. We've been having problems with low throttle KR and I have started removing timing to get rid of it, but with only a little luck.
    I've set both the high and low octane tables to 10*, but I see as much as 30* when scanning. I did find a "Max Torque Timing" table, but HPT recommends not to mess with it. Would that be advancing my timing above what the main spark table tells it to? Here's a screenshot of the timing from our last scan. Everything above 1000RPM should be 10*.
    Can't get timing to match table values!??! Attached Images
  2. #2 Re: Can't get timing to match table values!??!
    Hoffman/Schaumburg, IL
    If you're using Hptuners, in the 97-03's there is a timing add vs fuel mixture table, and it added 7*+ at some AFR's, there may be something similar in the 04'+s
  1. Michigan Grudge Match
    By Anthony Shaw in forum Shows and Events
    Last Post: 09-07-2008, 09:07 PM
  2. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
  3. Color match or Carbonfiber
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 03-27-2008, 11:43 AM
  4. Painting interior parts to match car
    By 99BluGP in forum Visual/Body Modifications
    Last Post: 02-17-2008, 07:35 PM
  5. Should altitude effect MAP values?
    By ghart999 in forum PCM Tuning
    Last Post: 01-11-2008, 07:23 AM
