If your first inclination is that you shouldn't, maybe you shouldn't. We shouldn't be convincing you otherwise when it doesn't work out, we are the bad guys.
Its not hard, but if you're not comfortable with playing around pc's and software, say like MS office Excel, then you might have an issue cause it's pretty much the same, but with bigger consequences. (blown engine, tranny)I'm not the biggest computer wiz but I definitely can figure it out, I'm not looking to do to advance things with it just log data maybe edit a few things I.E. fan run on when key off, TC lock speed, delete rear O2 codes....stuff like that, should I get HPT? Is it really that hard to set up a gauge screen with RPMs, LTFTs, KR for data logging?
You PAY to PLAY! Period... Each PCM you want to write to, will cost credits to unlock it!I know there's lots of good reads out there but you don't really know until you have it in front of you by then it's to late
also another big question, can I use it on more then one car? I have two and my friends could use tunes I'm not really sure how moving from car to car works, if I change computers can I just install it on a different lap top?
