Thread: What Trans Shift Points should I use?
Results 1 to 15 of 15
  1. #1 What Trans Shift Points should I use?
    Jul 2008
    Germantown, Maryland
    My car is basically stock, but fooling with my HPTuners I was wondering what would be a good shift point setup for performance without destroying my trans...
    Another question. While I'm logging during my VE tune I try to shift into second and keep it in second to get my lower rpms logged. Would there be a way to set my shift points so I can get these easier without slowing down and speeding up and forcing it to upshift/downshift?
  2. #2 Re: What Trans Shift Points should I use?
    TDCRacing
    Guest
    Stock car = stock shift points. The stock shift points make the rpm's go about 800-1000 over what the car's powerband is. Wich is where you want them to be.
    Why are you trying to log lower rpm's? What are you trying to do?
  3. #3 Re: What Trans Shift Points should I use?
    Jul 2008
    it's for my VE tune... I'm filling in boxes haha
  4. #4 Re: What Trans Shift Points should I use?
    TDCRacing
    Guest
    For that just drive like you normally do. It's easiest and most accurate that way.
  5. #5 Re: What Trans Shift Points should I use?
    Jul 2008
    Yea I've been doing it just driving down to work and such, but it still isn't filling in all the boxes....
  6. #6 Re: What Trans Shift Points should I use?
    Banned
    oswego
    Quote Originally Posted by Quicklynx View Post
    Why r u doing a ve tune?
  7. #7 Re: What Trans Shift Points should I use?
    Jul 2008
    Quote Originally Posted by Mikegotone'02 View Post
    It's more of a learning process for myself. I'm starting to learn how to tune with the help of some people, and before I get to the next step I am just fooling with some more minor things.
  8. #8 Re: What Trans Shift Points should I use?
    Banned
    oswego
    hmm, all i can say is read read read and talk to the people that have been doing it a while. That's where i learned lol. Just mention that you're a newb and we'll be easy on ya haha.
  9. #9 Re: What Trans Shift Points should I use?
    Barksdale AFB, LA
    It doesn't have to fill all of them in. Just the ones it can hit. If you can't hit a particular cell, there's no point in it being tuned.
    Some excel sheets can do "guess work" to fill in the rest to get it close. Not sure if Eddie's program can do that or not.
    2009 Subaru Impreza WRX STI
  10. #10 Re: What Trans Shift Points should I use?
    Jul 2008
    guess work isn't good enough for me haha
  11. #11 Re: What Trans Shift Points should I use?
    Barksdale AFB, LA
    But, if you're never going to hit that particular cell, what does it matter?
  12. #12 Re: What Trans Shift Points should I use?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Well put. And yes a VE tune is all a matter of opinion.
  13. #13 Re: What Trans Shift Points should I use?
    SE Level Member Stonewall's Avatar
    Rochester, NY
    Use the VCM controls in the scanner and command 2nd gear. It should stay in second.
    06 GT, HPtuner, PLX Wideband, AFC2.0, K&N CAI, PEM/PLOG 3"DP, ZZP 3.5MPS, CORSA CATBACK, GMPP STB's, GMPP HD Tarms
  14. #14 Re: What Trans Shift Points should I use?
    Jul 2008
    i know i know haha
  15. #15 Re: What Trans Shift Points should I use?
    Jul 2008
    thanks, I'll try that!
  1. Jacking points during trans install?
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2008, 07:33 AM
  2. Shift points
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-28-2008, 02:26 PM
  3. Reputation points?
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 04-15-2008, 05:29 PM
  4. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
  5. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
