Wait you have settings for the lucas injectors?
injectors.zipPart Number Delphi 01D030B
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Static Flow Rate: 48.83 lb/hr @ 58.0PSI (300kPa) or 370gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI
Coil Resistance: 15.9 Ohms / High Impedance
do you have this?
injectors.zip
use either 43.5psi or 58psi, the tables will come out the same.
