will i had my dad brake torque the motor while i looked at the motor itself and see if it was moving alot or alittle. it only moved slightly, like less than an inch of moving back and forth so i dont think my lower motor mounts bad >.<
what would cause the car to get burst knock right around entering boost as well as at the 1-2 upshift? im now leaning towards something physical hitting or rubbing. my downpipe is clear from hitting the subframe, dipstick's not touching anything. since imy tranny's having issues ONLY at a stop or near a stop. would free rev and if applied enough gas to have it pop back into first gear. i believe its a worn output piston from what was on trannyman's site. would it be something else in or around the tranny as a possibility?
just need some possible things to check. possible bad wire(s) that would cause burst knock?
