Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Jan 1970
    Maquoketa, Iowa
    Tiny Tuner - The Tiny Tuner
    Table Modifier - Table Modifier - The Scan Data Thingy
    Not sure but I think you just need a bin file for your car, edit it with Tiny tuner and only use hptuners to write the bin file to the car? It's been a while but I think that's what Eddie does, he only uses hptuner for scanning and writing, uses tiny tuner for editing.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Quote Originally Posted by FoSHO99 View Post
    HP Tuners is VIN, OSID, and PCM Serial Number locked among other things unless you have purchased the unlimited vehicle license for the specific model year of car and type of engine you are working with.
    If you have only used 2 credits to license your car/vin, I doubt you are going to be able to flash your PCM with a different .bin file unless that .bin file has your VIN and the same OSID number you are licensed to work with. Otherwise, you could get a VIN/OS mismatch error and HP Tuners will not allow you to reflash the PCM.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
