Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GTP Level Member apierce1289's Avatar
    United States
    I was planning on getting a ZZP pcm, do they set the codes to no reporting or do they completely remove them? I would like to have the computer know it has a bad CAT but just not show up in emissions check so I pass that way it wont keep running it since it will think its bad. Also can someone hook me up with Overkillwill's contact info cause I'd rather pay him to get the actual diagnostic test completely removed so it will never do that test again.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Quote Originally Posted by apierce1289 View Post
    How does the emissions testing stations in your area conduct their tests? Do they hook up their scan tools to check to see if the PCM reports a certain diagnostic test has run or not? If so, then just disabling the code will result in these tests always showing "NOT RUN" on the scan; and disabling the diagnostic may result in the same thing being displayed.
    I'm not sure what Overkillwill does, but you had better check to make sure whatever he does to disable the diagnotic test from running will report that diagnostic test result on the scan has "RUN AND PASSED"; otherwise you'll probably fail the inspection (that is if the smog guys are looking at this data).
  3. #3 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Quote Originally Posted by khung88876 View Post
    Man that was ALOT of reading lol, but i hope i dont have this problem from INTENSE? I'll be getting HPTuners soon, hope i can disable cat diagnostics? if it's not allready?
    When you get your HP Tuners setup, hook it up and scan while you drive with your INTENSE PCM. Keep an eye on your short and long term fuel trims, and also the B1S1 O2 sensor's voltage readout. If you see the O2 sensor voltage go high (above 0.800v) and stay there AND at the same time you see your short term fuel trim (STFT) and/or long term fuel trim (LTFT) go way into the positive and stay there, then your CAT and post-cat O2 diagnostics were NOT properly disabled in the INTENSE programming.
    -ryan
  4. #4 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Thanks bro, I'll look for that best i can, no rear o2 so do my best. Hey like your site' where you located?
    You just need to watch the voltage on the front O2 (B1S1).
    I'm located in Ft. Wayne, IN.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
