Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Quote Originally Posted by tylerbinski View Post
    So I should be alright with 98 PCM and no rear 02 sensor?
    I'm getting the exhaust done tomorrow morning, and wondering whether to have a rear 02 bung and sensor installed or not...
    advantages/disadvantages?
    98 PCM running 98 programming you should have no problems with a missing rear O2 sensor. BUT, you might want to install a rear O2 bung for a wideband down the road just in case.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Jan 1970
    Maquoketa, Iowa
    There are people who say tiny tuner has the ability to get rid of this diagnostic check.
  3. #3 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    old thread but i have a 01 gp and ever since i put in my catted dp i have gotten a code will a o2 sim work
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Quote Originally Posted by nascartech View Post
    Ripped straight out of the GM service manual for the P0420 code you said you are getting in the PM:
    To control emissions of hydrocarbons (HC), carbon monoxide (CO), and oxides of nitrogen (NOx), a 3-way catalytic converter is used. The catalyst within the converter promotes a chemical reaction which oxidizes the HC and CO present in the exhaust gas, converting them into harmless water vapor and carbon dioxide. The catalyst also reduces NOx, converting it to nitrogen. The converter also has the ability to store excess oxygen and release the stored oxygen to promote these reactions. This oxygen storage capacity (OSC) is a measurement of the catalysts ability to control emissions. The powertrain control module (PCM) monitors this process using a heated oxygen sensor (HO2S) located in the exhaust stream past the three-way converter. When the catalyst is functioning properly, the HO2S 2 is slow to respond to a large change in the HO2S 1 signal. When the HO2S 2 responds quickly to a large change in the HO2S 1 signal, the OSC and efficiency of the catalyst is considered to be bad and if subsequent tests also indicate a failure DTC P0420 will set.
    Sounds to me like the cat that came with your DP isn't compatible with your car, or it isn't working properly.
    -ryan
  5. #5 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Fort Wayne, IN
    Quote Originally Posted by FoSHO99 View Post
    I've heard the same thing and I have tinytuner. I haven't found anything in it at all that gives you the ability to disable these diagnostic tests. Now if there is a new version of TT that can do it, I would like to see it. But so far, nada.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
