Thread: Is my PCM tuned? How to tell?
Results 1 to 7 of 7
  1. #1 Is my PCM tuned? How to tell?
    Jul 2012
    tulsa
    Was wondering if there was a way to know if the PCM on my GTX has been tuned? I looked at it and it has a white sticker that simply reads White GTX thats it. Any way of knowing if mine may have tuned at some point Wish i knew the previous owner. I would really like to ask him some questins about this GTX? lol
  2. #2 Re: Is my PCM tuned? How to tell?
    Normally "tuned" "canned" PCM's will have a name on it, like ZZP, overkill, Digital horsepower etc etc.
    If its been tuned via a DHP tuner or HP Tuners there is no way to tell. You'd have to ask the owner before you.
    White GTX might be what GM and SLP put on the PCM when it left the factory.
  3. #3 Re: Is my PCM tuned? How to tell?
    Jul 2012
    tulsa
    Are there any performance aspects i could look for that only a tuned PCM would do. IE a Fan temp turn on? SHift points? 40 mph WOT lag? I know at 40 I can punch it and the tranny drops to second gear and its balls to the wall. How bad is the lag usually on stock tuning?
  4. #4 Re: Is my PCM tuned? How to tell?
    Jan 1970
    Maquoketa, Iowa
    The fans stay on for a little bit after key off?
  5. #5 Re: Is my PCM tuned? How to tell?
    Jul 2012
    Chicago
    Pulls in first when you nail it at 40 MPH?
    -Carl
  6. #6 Re: Is my PCM tuned? How to tell?
    Jul 2012
    tulsa
    At 40 I can punch it and it downshifts and pulls pretty hard. That's what kinda makes me think it might be tuned. The fans don't stay on after I turn off the ignition though. But it does have a 180 tstat in it tho don't know if that means anything? I ve got a 3.4 pulley I want to put on but I hesitate to do so without knowing if its tuned or not. Idont have headers or 3" dp but I do have the ubend removal with cat delete and slp cat back so I feel comfortable running it if it has a tune
  7. #7 Re: Is my PCM tuned? How to tell?
    No flow mods, no pulley drop.
    A u-bend delete and catback is not enough, even if it was tuned.
    Sounds like the PCM is 100% stock to me. I would advise you to read a little more on what mods should be done prior to reducing the size of the supercharger pulley.
  1. Do I need a tuned PCM.
    By Jbruce in forum PCM Tuning
    Last Post: 07-30-2011, 06:36 AM
  2. Tuned PCM.
    By GTP 40TH in forum General Tech Discussion
    Last Post: 06-16-2011, 06:07 AM
  3. Is my PCM tuned already?
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 01-29-2011, 07:18 PM
  4. Help me with a Tuned PCM!
    By extreme in forum 04+ Specifics
    Last Post: 02-04-2010, 07:29 PM
  5. got the car tuned
    By QwikGT in forum Off Topic Discussion
    Last Post: 08-21-2008, 04:22 AM
