Thread: MAF Tuning Help Needed
Results 1 to 7 of 7
  1. #1 MAF Tuning Help Needed
    Feb 2008
    I'm trying to dial in my MAF, but I'm getting something like this on my LTFT's. I've already raised the lower end up to 8999 Hz by 20%. I think the lower range needs to come up more, but I'm not 100% sure what to do with the mid/upper regions.
  2. #2 Re: MAF Tuning Help Needed
    Feb 2008
    I did a little bit of tweaking, but I'm not getting much closer to 0. I've scaled back 2% twice, now, but my numbers haven't changed much from the two previous scans.
  3. #3 Re: MAF Tuning Help Needed
    Oct 2008
    Michigan
    If you are dialing in your maf why are you using a VE histogram?
  4. #4 Re: MAF Tuning Help Needed
    Feb 2008
    I'm looking at my LTFT's Should I be looking at something else??
  5. #5 Re: MAF Tuning Help Needed
    Oct 2008
    Michigan
    Yes you should. Shoot me over your tune file, log file, and config file. Send it to admin@ottperformance.com , I'll get you setup.
  6. #6 Re: MAF Tuning Help Needed
    TDCRacing
    Guest
    Quote Originally Posted by fast98 View Post
    Right. The MAF table is a linear table. So In other words it looks exactly like the maf table in the editor does. You can tune trims like this also (by using the VE table) but it's a mater of opinion really. I have always used the MAF to tune fuel and trims.
    You have to setup up a custom histrogram. I'm guessing he is doing this for you. So let us know how it goes.
  7. #7 Re: MAF Tuning Help Needed
    Oct 2008
    Michigan
    Quote Originally Posted by TDCRacing View Post
    Yes I'm gunna set him up with the correct config file for this. I also like to look at people tunes when I help so I can give them advice if needed.
  1. Customization Help Needed.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-02-2008, 11:13 AM
  2. CarFax Needed
    By JJ91284 in forum Off Topic Discussion
    Last Post: 07-02-2008, 11:42 AM
  3. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
  4. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
