Thread: 2000 gt need tuned
Results 1 to 13 of 13
  1. #1 2000 gt need tuned
    Aug 2012
    saginaw MI
    i need my pcm tuned idles ruff sometimes i just put new weires an plugs in i want shift points rasied is their anyone around 48626 area code that can do it
    Solve your mechanical issues first.
  3. #3 Re: 2000 gt need tuned
    Aug 2012
    saginaw MI
    ita the pcm makin it idle ruff an it only dose it sometimes
  4. #4 Re: 2000 gt need tuned
    How do you know it's the pcm? What mods do you have done?
    99% of the time its not.
    Might be a maf issue.
  6. #6 Re: 2000 gt need tuned
    Aug 2012
    saginaw MI
    i have no mods yet i just did weires an plugs an which one is the maf the bigger plug on the throttle body?
  7. #7 Re: 2000 gt need tuned
    With no mods if your car runs rough its not a problem that can be tuned out. You have to fix the problem as to why its running that way before you get it tuned
  8. #8 Re: 2000 gt need tuned
    Aug 2012
    saginaw MI
    okay well i might of pin pointed it it quit an it would only stay ruining when i keep my foot on the gas an i put it in gear an got on it an seams like carbon was just built up bc the egr was throwin a code could that be?
  9. #9 Re: 2000 gt need tuned
    when you have your car scanned those codes are directly related to your cars problem, post up the code you have, and we can go from there.
    also remember. any time your cel light is on, even if the car feels fine, its not running at 100%. the car will run like real crap after some time, you will loose fuel mpg. and cause other problems. all the sensors need to be working together. with a cel light on that stops happening.
  10. #10 Re: 2000 gt need tuned
    Aug 2012
    saginaw MI
    yeah i noticed bad gas an let me try an find the slip that i wrote it on an ill post it an if it is the egr an i just plug is an get it tuned out?
  11. #11 Re: 2000 gt need tuned
    you can go that route.
    the tube could be cracked, causing a big vac leak, or its clogged. even the wires to the plug can be cracked and showing bare wires.
  12. #12 Re: 2000 gt need tuned
    Aug 2012
    saginaw MI
    i cant find the paper with the code an i dont have my scanner an the plug was cut before an i had to tape them up an i was told the tube could be clogged to before guess i gotta go get drity ehh lol
  13. #13 Re: 2000 gt need tuned
    GT Level Member Beelzeboul's Avatar
    Racine
    its pretty easy to get off and picking up one from the jy isnt too bad either I would start at the wires though after I deleted my egr it tended to idle a lil rougher but evened out after I did pcm relearn runs and idles fine now
    Sometimes the cars better with a ses light till I get a tune anyway
    I'm sorry officer I didnt know I couldn't do that
  1. new tuned pcm.
    By gunsn88 in forum PCM Tuning
    Last Post: 10-25-2011, 08:55 PM
  2. Which tuned ECM for an 05 GTP?
    By ls1freek in forum PCM Tuning
    Last Post: 10-20-2011, 02:59 PM
  3. Tuned PCM.
    By GTP 40TH in forum General Tech Discussion
    Last Post: 06-16-2011, 06:07 AM
  4. got the car tuned
    By QwikGT in forum Off Topic Discussion
    Last Post: 08-21-2008, 04:22 AM
