Thread: LTFT moving in open loop (O2 unplugged)??
Results 1 to 20 of 45
  1. #1 Re: LTFT moving in open loop (O2 unplugged)??
    Feb 2009
    flintnasty MI
    Voltage offset is base offset, offset vs vacuum is short pulse adder and min pulse width is the mininum pulse width allowed after offset before fuel trims.
    Calculate the required IPW based on dynair and offset in pcm. It works as its supposed to.
    Dead time varries based on voltage and pressure across injector. There isnt one set value it uses all of the time.
    It doesn't work like that but OK.
    Op. Don't mess with offsets on 60s... it doesn't work like it should.
  2. #2 Re: LTFT moving in open loop (O2 unplugged)??
    Believe it or not, I'd need something more than your word on that.
  1. P0171 open loop
    By gtpsleeper in forum PCM Tuning
    Last Post: 10-19-2011, 04:05 PM
  2. Changing plugs. Cant get the wires unplugged.
    By Wakeboy1337 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 12:52 PM
  3. Closed loop?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2011, 05:47 PM
  4. Open/Closed Loop Operation
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2009, 08:52 PM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
