Quote Originally Posted by Justin48 View Post
Hey all so here it is like a year and half and back to fiddleing with the tuner and starting to get my busted parts on order... so at some time getting tunes to trying to tune my shift tables have gotten jacked up... and i have had high ****ed up WOT speed/rpm shifting and i am sick of it..
So here is my problem at WOT my tach. will damn near run over the 7000rpm from 1-2 the shift is sloppy and LOOOOOooong and kinda "pops" into 2nd. its about 58-60mph when it starts its shift and around 68mph when its set into 2nd. i have it set on peformance shift... (normal is worse) i have tinkered with the shift rpms and speeds and it just ignores them and keeps shifting at the same time. Below is my current tables. Trans also has a zzp shift kit installed...
Thank
Gear MPH
1-2 55
2-3 108
3-4 140
2-1 49
3-2 105
4-3 135
Gear RPM
1-2 5900
2-3 5900
3-4 4700
You need to correlate your shift points with the actual shift speeds.
0 out the mph and get some good scans. make note of what gear you're in and what gear shifting into.
Hopefully you haven't beat on it too much with these asinine settings and thrown your balancer pulley
