So yesterday I headed down to cecil dragway and see how the car’s running. First pass I ran my WB was showing 12.7-13.0 with knock so I lowered the timing during the drive down the track, but the most was from the dig right when I went into PE with as much as 9* of burst knock retard. Picked up my slip and it was 13.8@101
Second pass I richened up the 8-11 range in the MAF via AFC 2.2. again off the car bogged due to burst knock up to 9* and it zeroed out as I continued to hold throttle. WB was showing 11.7-12.0 with minimal knock through 1st gear but started getting KR towards the top of 2nd into 3rd, like 4-5*. I ran a 13.9@101.
Last pass of the night I was pissed. Richened the 8-11 way above usual and lined up. once ***ing again I bog off the line because of the burst knock but again, it’ll zero out and the WB was showing 11.3-11.6. im thinking sweet, go pick up my slip and I ran a 14.1@100!?? W…T…F….?
As I pulled over to the pit area I looked through each log. Areas where I had no knock my timing was at 15-16* of timing , YET my timing commander was adding add’l 5*, which should of made timing set at 19* with zero knock. My NB for the second and third runs were 990-1025, wayyyyy rich but the WB showed different otherwise. I believe either the WB sensor crapped on me a while ago, since at idle and cruise it would show “LEAN” or i bet my rear header has a major leak that it’s that bad to throw off the sensor as well as my LTFTs at idle/or off throttle shoot to +16.4.
By the way, this was with the 3.3” MPS and no alky. Tires were set at 26psi and the track didn’t appear to be very well prepped/sticky. Ran with a quarter of 92oct gas.
/end rant
im really debating swapping back to 1.9stock modified rockers since i had better luck tuning that than the cam![]()
