Thread: wideband being weird
Results 1 to 11 of 11
  1. #1 wideband being weird
    went for a drive and noticed out of the blue my wideband gauge is cycling like a narrowband would read??? If I give it some throttle it goes back to normal... then it will randomly read normal on regular driving... then start cycling again???
    Any ideas what could be going on?
    maybe a bad o2?
    Thats how our pcm operates in closed loop.
  3. #3 Re: wideband being weird
    Grand Island, Nebraska
    Mine does this too...in fact it almost always does it unless im at PE, so yes its in closed loop.
  4. #4 Re: wideband being weird
    this is an AEM augo wideband not just some narrowband gauge hooked up to my stock O2 and Ive had for about a year now... isn connected to the pcm at all.... and has never "cycled"...
    this is not normal for a wideband...
  5. #5 Re: wideband being weird
    So what numbers is it sweeping from?
    Mine always does 14.3 to like 15.4 while bumming around.
  6. #6 Re: wideband being weird
    see its not bumping like that... as Im cruising itll read like "15.2" then bounce max lean.... then back to X... etc etc just like a narrowband gauge would...
  7. #7 Re: wideband being weird
    alot like this only not the same number...
    AEM wideband problem - YouTube
  8. #8 Re: wideband being weird
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    ah **** i was gonna say mine goes back and forth but damn not like that
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  9. #9 Re: wideband being weird
    Been looking for the last few days and have found different people with the same problem but no solution...
    gonna test the AEM 02 today...
  10. #10 Re: wideband being weird
    update in case this happens to anyone else... did a test on the 02 and it turned out to be faulty...
    Thanks for the update.
  1. wideband 02
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 05:53 AM
  2. Wideband
    By Wrongwayislost77 in forum PCM Tuning
    Last Post: 02-28-2011, 12:51 PM
  3. AEM Wideband o2
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 04:23 PM
