I know. I just wanted to hear how he came up with that.
exhaust gas is inert, meaning it has no combustion efficency. it does not burn. less combustion equals less pressure and lower temps.
that is the purpose of the egr, to keep combustion temp down to prevent the emission of NOx, that is its only purpose. to lower combustion temps at idle and cruise.
deleting the egr would delete the cooling effect it has on the combustion chamber.
i can go into further detail if you wish.
Also reduces fuel consumption.
But alas, some engines have passed emissions without such devices.
so far i have found the metal tubing from my egr to my LIM cracked open at both ends, have not fixed exhaust leak yet.
The tubes did fix the leak. Fixed exhaust leak and new injector o-rings.
Like dark horizon said im always gonna be pegged at idle.
0's out under throttle
That's just cause your cam? Seems odd you can get fueling at idle to settle no matter the tune
this cam has valve overlap that causes oxygen to get pulled out during the exhaust stroke, the the o2 reads extra oxygen and dumps fuel
i could get it tuned better and have more timing at idle and low rpms to counter that.
i will get all that taken care of when i get it dyno tuned
It shouldn't matter though idle tuning is idle tuning don't need a dyno for that and even for us ls motor guys with cams ltfts still don't peg I hope its just the tune that needs to be adjusted
