yeah, he is there. sometimes just takes a little bit for him to answer.
I emailed Will (overkill) about 3 weeks ago, and still no response. I am going with Intense.
im planning on ordering a pcm in the next few days but idk which to go with. overkill or intense? overkill seems too hard to contact so i think im just gonna go with intense.
I had trouble contacting Overkill (he still hasn't replied and it has been over 6 weeks! So i went with intense and just put it in over the weekend (along with the Intense Fenderwell Intake kit, and plugs, and other little things; as part of their Stage one performance package). It is absolutely incredible difference, and their customer service is incredible.
I definitely recommend going with Intense!
They are really fast, it shouldn't make much if any difference that u made a few adjustments. They have to put the vin in all of them, so they all need a few things (so im sure its just a keystroke for them to adjust it). I only have the GT and it is incredible difference. Hope you have fun with it!
did you get yours yet? For other users who have had it awhile.........are you happy with it?(intense)
Hey,
I have had mine for about a month or so now and its incredible. With the PCM and the FWI i get 523km in the city, a 100+ km increase. That in it self is worth it to me, plus the definite increase in performance.
i emailed 3800performance today about their pcms. they told me they are most certainly NOT zzp pcms. when i replied and asked who did them, they said they had a local tuner that does them....
anyways, for all of you with intense pcms, did any of you need to go get a CASE relearn done after installing it, or was it fine without?
Mine was fine without it, it backfired once then was fine. But i know a guy at the Pontiac dealer so i got it done anyways.
Hey Guys, just joined & is my 1st time posting. I got a 2005 GP Base 3800V6 and i want a PCM also. After reading a lotof threads on this site, It seems like Intense is the company of choice due to the fast shipping & quality of the tunes... about the case relearn, does it need it? the one guy said his car was fine, backfired once, but is all good. I do not know anything, well very little, about case relearns... Hard to do? necessary for re-programmed PCM? I just got my car 3 months ago, 56k, and i just want to up the HP. $ is not a huge problem and i am willing to spend $. I just have a hard time finding parts for the 2005 Base model grand prix, everything is for <2003... i even thought of maybe getting a turbo kit for it if i decide to keep the car (long term) or i thought of just small upgrades until i get a newer ride.. any good sites? ay help is much appreciated! thank a lot guys! ~ Josh N
Hi,
go with overkill!
it is the best ecu you can get.
Will had a wedding this past week!
try to re e-mail him! at willoverkill@gmail.com
thanks, jason![]()
im thinking about getting a ZZP PCM because i also want the HV3 Upper intake insert.i figure i should just get both at once, right??? i think those 2 + my CAI should do the trick.... just hoping for around 230hp anything higher and i will be pretty happy. ~ 05 Base GT GP
zzp pmc's are not that good.
bad shifting on the trans.
Im at the INTENSE website and about to get a PCM. I want some information from you guys. I have a 2005 NA engine (L26)with Stock internals &...
1.Should i leave my timing tables stock or choose the 1* option for $20 more?
2. what should i choose for my transaxle shift settings? Leave at stock (+$20) or raise to approx. 6000RPM($0)?
3. i am also going to be getting a HV3 Intake Insert in the upcoming months. should i have the PCM programmed for this mod? will it have a negative effect if its tuned for it and its not installed until a later date(HV3)?
Any input on which settings i should choose would be great!
