You can use a tuner to change the maf table to add or subtract fuel from the frequency range, but that doesn't change that the maf will run out of frequency range based on airflow ceiling. The AFC makes the PCM think that the maf isn't getting as much air through it by scaling it back so you can run more air with a higher ceiling or more flow. If that makes sense.
