Thread: PCM on a NA GP
Results 1 to 20 of 21
  1. #1 PCM on a NA GP
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    I was just wondering if someone could point me in the direction to get a pcm tune for my GT, it doesnt have a SC, so i wasnt sure if I can tune it... Help a kid out?
  2. #2 Re: PCM on a NA GP
    you can tune it.
    You can buy a tuned GT pcm from a vendor, or get it tuned by a local, if you know someone that knows what they are doing.
  3. #3 Re: PCM on a NA GP
    GTX Level Member cerick08GP's Avatar
    There are a couple good places to buy a boxxed tune like Overkill or the W-body store. Make sure to tell them about your engine swap
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    yeah most of my car smart friends are ricers so foreign is all they know.. would you happen to know a vendor where i can get this pcm tune?
  5. #5 Re: PCM on a NA GP
    Dec 2011
    Philadelphia, PA
    or get a custom tune or overkill, thats what everyone told me and thats wat im goin to do, im leaning towards overkill tune tho
    AEM bruteforce intake
    Diablo 93 Octane tune
  6. #6 Re: PCM on a NA GP
    intense or a 3800 pcm.
    Its better to have some mods done to make they pcm upgrade worthwhile.
  7. #7 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    yeah i'm in the process of making a CAI/WAI. and then also going to get SD headers
  8. #8 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    Also i have just a bottomswap i believe, because my intake manifold is still 98 styled, but it was installed 2007
  9. #9 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    Also.. not to be too annoying hhere. what should i get on a tune? for example, increasing the WOT ignition timing tables, the thermostat 180 or 160, and the WOT shifting times.
  10. #10 Re: PCM on a NA GP
    Quote Originally Posted by Kolton Lock View Post
    IMHO
    1. Tweaked timing is good, but if they say run premium gas with their tune and you don't
    I'd stick to stock(-ish) timing.
    2. Thermostat I'd go with neither, stay stock.
    Unless you have money to piss away every day, for a couple extra horse you will probably never need.
    2008GP
    2002GP||sold
  11. #11 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    so i wont get any noticable mpg difference? cause i'm getting 14ish conservatively... I'm gunna try spark plugs for a start
  12. #12 Re: PCM on a NA GP
    if you are only getting 14 mpgs, it might be time for a good tune up.
  13. #13 Re: PCM on a NA GP
    Umm huh. If you tell me what you want the tune to do and who you want to buy it from I'll be gald to given my opinion and a breif explaination. Spark plugs are a great first step to restoring better mpg, I recommend NGK TR55s.
    2008GP
    2002GP||sold
  14. #14 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    yeah i'm tuning it up before i do anything,
    Basically i was thinking a tune from Intense. and i just want better mpg with possibly better performance
  15. #15 Re: PCM on a NA GP
    Ok but one key word in Intense’s name is “racing” their standard tune is fine so nobody flame me here. But the mpg options they are going to add up on the cost. For all around driving I’d look at Overkill dude. Anyway here I go as stated.
    Option 1 = Stock idle speed (+100RPM is for cammed cars)
    Option2 = 195 F thermostat (colder just costs mpg)
    Option3 = stock (or if you do want a few extra hp might as well go +3if you want to run premium gas)
    Option 4 = disable rear O2 sensor DTC (lets to remove your cat later if you like)
    Option 5 = stock shift points (the higher options you really should have valve train work first)
    If you still want this tune, just take the $175 option I think you save a few bucks.
    2008GP
    2002GP||sold
  16. #16 Re: PCM on a NA GP
    Mar 2012
    Minneapolis MN
    Thank you very much, i like your opinion.
    And the overkill would be the 87 octane option then?
    or 91+ if i want premium?
  17. #17 Re: PCM on a NA GP
    Yup, Overkill has less stated options. But if you read the fine print he really tweaks the PCMs. Judging from our conversation you should totally just go for the 87 octane tune. If you noticed he doesn’t try to trick you into thinking a colder thermostat is a good idea. But he does disable the low temp code if you choose to do it later. IMHO stock thermostat is the best for anyone, except the boosted ppl looking for that last few HP and KR protection.
    Some thing to consider is that running premium gas will cost you money every day. Ya sure, you could (maybe) not run it by babying the engine. But then you go to pass someone and pow there goes a hole right threw your #5 piston. Or better yet, your gf (or whom ever) fills up your car with 87 octane with you not knowing, best case scenario your car engine has so much KR it is now SLOWER than stock and uses more gas.
    I have a friend that drove a turbo for years and always used 87 octane. The car ran for $hit and got way less than EPA mpg, but refused to use premium.
    2008GP
    2002GP||sold
  18. #18 Re: PCM on a NA GP
    Kansas
    Mod more, then it would be beneficial for a tune. But do your tune up first: plugs, wires, fuel filter, few other things. As previously stated keep the stock thermostat. All you will do is waste fuel as the engine is not running optimal temperature.
  19. #19 Re: PCM on a NA GP
    Deleting the EGR = loss of fuel economy.
    But its cool.
    teach anti-logic.
    Its all the rage these days.
    dood.
  20. #20 Re: PCM on a NA GP
    Kansas
    Fixed.
    Thanks Chief!
pcm
